Mark Allanson
| posted on 25/9/07 at 06:30 PM |
Quick question before I blow up my new PC
Is this the power supply connection for this USB card?
I bought it off ebay but it came with no instructions, the little connector that runs off the molex loom fits, but would like a bit of reasurance
before I flick the switch
Thanks in advance
Mark
Catpuss
| posted on 25/9/07 at 06:48 PM |
I would expect the power to come from the edge connector. That may be an extra connection to say USB ports on your case or a front bay.
I dont think you need to connect anything to it. You get the power for the board through the connectors along the edge
Mr G
| posted on 25/9/07 at 06:53 PM |
If it's a combo USB2 and firewire card the connector is if you want bus power for the Firewire ports.
It's always recommended to use seperate external power supplies for firewire devices anyway.
ReMan
| posted on 25/9/07 at 07:09 PM |
Looks like the option to power it with teh old floppy drive power connector type thing. USB can probably draw more than can be supplied off PCI slot
alone
Scotty
| posted on 25/9/07 at 07:16 PM |
yes, you will be safe to connect floppy sized power connector to that, as said above , extra power preferred - just like us !!
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
Mark Allanson
| posted on 25/9/07 at 07:50 PM |
thanks everyone, XP pro is being installed as we speak (I on the lappy at the mo), all seems OK until something goes wrong!!
| posted on 25/9/07 at 07:53 PM |
Looks very much like the one I just bought on Ebay.
Works very well with Firewire. Its supposed to be USB2.0 but XP doesn't recognise it as such on all the ports, only on 2 of the 4
(strange!!!)...
