Author: Subject: Odd broadband speed problem
Mark Allanson
posted on 20/10/07 at 08:51 AM Reply With Quote
I am with Pipex and have had excellent speeds until last week when I first noticed this weird problem.
When first booted, the connection is around 5meg and progressively slows down the longer I use the connection until after an hour it is sub dial up speed.
I have changed the DNS server numbers but it has made no difference, I live 400yards from the exchange, no virus found by AVG or any online checkers, regcleaner has cleaned, I don't know what to check next.
Any ideas?
Mark
posted on 20/10/07 at 10:03 AM Reply With Quote
Sounds like an equipment problem at either your end or the exchange, I had something similar just over a year ago it was the card at the exchange took a long to get it fixed, it was only after the voice line also went down that I managed to get it fixed.
To prove it you will need to try another router.
andyharding
posted on 20/10/07 at 10:39 AM Reply With Quote
This will give you a positive read out of your download speed for comparison purposes:-
http://www.inetc.co.uk/speedtest/
phoenix70
posted on 20/10/07 at 10:48 AM Reply With Quote
Do they have any download limits, if so have you hit it and they are throttling you back
tegwin
posted on 20/10/07 at 11:47 AM Reply With Quote
Stop downloading the porn....that will speed things back up again
eccsmk
posted on 21/10/07 at 10:09 PM Reply With Quote
sorry to hijack but i tested mine and it saysmy download speed is
698.9 Kbps.
posted on 22/10/07 at 10:44 AM Reply With Quote
698.9 Kbps.
How far are you from the exchange ?
Braoadband speed depends on distance, and other factors that effect line attenuation and signal to noise ration
Most modsem-routers have a diagnostic page that you can use to test the attenuations and snr.
[Edited on 22/10/07 by britishtrident]
