Dusty
| posted on 15/11/07 at 09:52 PM |
Can't get on rhocar
Since monday my desktop (firefox or IE, XP home, AVG, CCleaner, spybot, Adblock Plus) can't access the robinhood website at
http://community.rhocar.org/ Error message says the server has timed out.
All my other usual web haunts are fine and the computer seems to be normal otherwise. I tried my laptop (98SE) over my virgin broadband router last
night and it did exactly the same.
I haven't made any changes to either computer. Anyone any ideas what I can check to find where the fault lies. Other hoodies tell me the site is
up and running normaly.
Please, no answers along the lines of 'Why would you want to?'
[Edited on 15/11/07 by Dusty]
mitch2b
| posted on 15/11/07 at 10:12 PM |
no problems here,
even you link works, have you tried via IExplorer ?
Mitch
RichardK
| posted on 15/11/07 at 10:25 PM |
Could be loads of stuff mate, I would flush my dns cache first
Start button, Run, in the run box type in cmd and press ok, in the black dos box that will appear type ipconfig /flushdns when that completes type
ipconfig /registerdns
Give that a whirl and come back if no luck.
Regards
Rich
Gallery updated 11/01/2011
Dusty
| posted on 15/11/07 at 10:50 PM |
flushed and registered with no effect. IE and firefox both refuse to play ball.
My link doesn't work for me! Is it odd that rhocar is the only site affected?
RichardK
| posted on 15/11/07 at 10:53 PM |
So you can get on everywhere else just not rhocar, is that right?
If so I would check the MTU (Max MTU)value next and change it to 1492 if you are a broadbander or 576 if on dial up, Download Dr TCP to do this from
HERE, select your network card and then note down what you current MTU size is and then replace it with what I
suggest. Click Save then Exit and Reboot you pc and try again.
[Edited on 15/11/07 by RichardK]
Dusty
| posted on 15/11/07 at 11:08 PM |
Yup, everywhere else, just not rhocar.Maybe I've been banned!
OK doing the MTU thingy.
RichardK
| posted on 15/11/07 at 11:25 PM |
Ok off to bed !
Good call Rob should have suggested that earlier!
If the max mtu size setting and recycling the router don't do it for you, the only other thing I can think of just now is a modified hosts file,
maybe the ad blocker program has modified this for you, do a search for a file called hosts with no file extention, it normally lives in
C:/WINDOWS/system32/drivers/etc open it up with notepad and a normal unmodified hosts file should look like this, if stuff has been added to the
bottom then this could be the problem. Copy and paste a copy of the file then modify it/delete the end lines and then save, reboot your pc and try
again.
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
Dusty
| posted on 15/11/07 at 11:39 PM |
Thanks for the above. I'm still trying to fathom the DrTCP thing. Seems my MTU is 1500 and tweak test says I'm at 96% efficiency and
something that should be between 18980-51100 is at 65535. And very shortly I will do something which means I have to go to PC world and buy a new
computer tomorrow. Assuming I survive the explosion.
Dusty
| posted on 15/11/07 at 11:54 PM |
MTU reset to 1492.
Receive window reset to 51000.
Router rebooted.
No joy.
Dusty
| posted on 16/11/07 at 12:02 AM |
OK. Ping timed out as did trace.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Nigel Thurstan>ping community.rhocar.org
Pinging community.rhocar.org [208.116.49.178] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 208.116.49.178:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Documents and Settings\Nigel Thurstan>tracert community.rhocar.org
Tracing route to community.rhocar.org [208.116.49.178]
over a maximum of 30 hops:
1 6 ms 7 ms 7 ms 10.188.0.1
2 7 ms 7 ms 11 ms 80.235.128.36
3 15 ms 17 ms 17 ms 195.188.231.21
4 14 ms 14 ms 14 ms 195.188.231.6
5 16 ms 15 ms 14 ms 194.117.136.142
6 18 ms 17 ms 14 ms 194.117.136.146
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 *
???????? Sorry. Havent a clue what any of this means.
chockymonster
| posted on 16/11/07 at 12:21 AM |
The router here
Doesn't know where to go next
It looks like it's a routing issue with your isp/peering partner. The packet seems to get lost inside of telewest somewhere (makes a change)
Dusty
| posted on 16/11/07 at 12:29 AM |
I've done the trace thing twice more and it gets to the same 194.117.136.146 and gets stuck.
What now? Contact virgin, my ISP?
Will I never post on rhocar again? Will I live happily ever after? What is this nasty little rash? Will that nice but cruely poisoned spanish man send
me 30% of his fortune? Why do computers have to be so hard? Will this smog ever clear from the remains of my brain?
Thanks for all the help.
[Edited on 16/11/07 by Dusty]
chockymonster
| posted on 16/11/07 at 08:07 AM |
Virgin, telewest, same difference
Yes, call them, they'll be sod all use but it's a problem with them
RichardK
| posted on 16/11/07 at 09:19 AM |
See if you can use a proxy whilst they fix it, a good one can be found HERE
Just a thought may work as a temporary fix.
Regards
Rich
skodaman
| posted on 16/11/07 at 07:46 PM |
Hey it could be worse.
What if u couldn't get on this site? Because of AOL I couldn't log on to this site for nearly a year now that's serious.
Mind u I'm a member of Rhoboat as well.
PS. U wanna buy a 2B mirror finish ss bonnet?
Skodaman
Keith Weiland
| posted on 16/11/07 at 08:21 PM |
going by your trace route you arent resolving domain names so your DNS server might not be working properly. I would call Virgin and get them to
resolve it. Be aware they now charge for support but will credit the call if it turns out to be thier problem so make sur eyou ask them for a credit
at the end of the call.
Dusty
| posted on 16/11/07 at 11:18 PM |
Woohoo. 2 emails to the support staff at virgin and were back although a bit glitchy.
Tracing route to community.rhocar.org [208.116.49.178] over a maximum of 30 hops:
1 17 ms 12 ms 10 ms 10.188.0.1
2 9 ms 8 ms 8 ms 80.235.128.36
3 19 ms 15 ms 15 ms 195.188.231.21
4 19 ms 15 ms 18 ms 195.188.231.6
5 18 ms 14 ms 15 ms 194.117.136.142
6 16 ms 16 ms 15 ms 194.117.136.146
8 111 ms 132 ms 110 ms tge2-4.ar1.nyc3.us.nlayer.net [69.31.95.125]
9 110 ms 114 ms 229 ms tge1-4.ar1.ewr1.us.nlayer.net [69.31.95.157]
10 86 ms 90 ms 85 ms fortressitx.ge3-23.ar1.ewr1.us.nlayer.net [69.31
.95.86]
11 87 ms 90 ms 110 ms 208.116.63.225
12 88 ms 85 ms 86 ms server.dataproductservices.com [208.116.49.178]
Step 7 still seems to have a problem but overcomes it.
