Gergely
| posted on 13/12/07 at 10:06 AM |
PowerPoint help needed - sound files
Hi, Maybe one of you can help...
I want to add a short music fle to play when my slideshow starts and loop it when the music ends.
I can do it, it works on my computer, but when I send it to someone it doesn't play as it links the music file instead of embedding it in my
presentation.
I have tried adjusting the limits of embedded object sizes, but still not working.
The actual presentation is 3010KB and the music file is only 53KB.
How can I make sure that the recipients also hae the music play on their PCs?
Thanks!
Gergely
| posted on 13/12/07 at 11:23 AM |
http://office.microsoft.com/en-us/powerpoint/HA010348231033.aspx
How do I change the maximum size allowed?
1. On the Tools menu, click Options.
2. On the General tab, increase the Link sounds with file size greater than ___ Kb setting to a size just larger than your largest sound file, up
to 50,000 KB (50 MB).
3. Click OK.
Gergely
| posted on 13/12/07 at 12:13 PM |
Yes, thanks, but that is what I have done and it still doesn't work...
| posted on 13/12/07 at 12:41 PM |
Good point- I should learn to read!!!
geoff shep
| posted on 13/12/07 at 02:04 PM |
This doesn't solve your embedding problem but can you send them the sound file along with the ppt file (on the same CD if that's the way
you are sending it) and see if will still link.
twybrow
| posted on 13/12/07 at 05:35 PM |
I think that is the way you would have to do it. Copy both to the cd, then add the link to the file. That way it should look for it on the cd, not on
your pc.
Gergely
| posted on 14/12/07 at 08:52 AM |
OK, thanks guys! I will do that then.
I am just disappointed, as sometimes you receive funny slideshows with music, so those are clearly embedded somehow...
Oh well...
Thanks!
geoff shep
| posted on 14/12/07 at 07:46 PM |
Try this Powerpoint help, look for package CD command halfway(ish)
down
