finlay
posted on 7/2/08 at 10:45 AM |
hayabusa clutch slave cylinder bracket, help
hello all
i was just about to drop in my busa engine into my MNR when i thought i would just dummy fit the clutch slave cylinder bracket into place to double
check the output shaft flange wont foul, and it does, its the securing bolt directly accross fom my thumb that attaches the slave cylinder to the
bracket is just fouling the flange
see pics
MNR had machine as much as possible from the bracket but it still fouls
any suggestions or what have fellow busa BEC builders done ?
much appriciated
Finlay
mackei23b
posted on 7/2/08 at 11:28 AM |
Hi there
Westfield do a kit, it's £220 (Ouch!). You may get an idea from it though.
Ian
WITCH HUNTER
posted on 7/2/08 at 01:29 PM |
Go with the westfield kit.it works a treat .got one on mine.
hunter
finlay
posted on 7/2/08 at 02:18 PM |
oh well another 200 bites the dust![](/images//smilies/sad.gif)
Jason Fletcher
posted on 7/2/08 at 04:51 PM |
I just bought one from Karl at Extreame engines. Its a very nice unit but expensive at £130 plus the vat. Nova racing make the main part and it not
badly priced and they can advise you what piston you will need. Its a propper job!
Jason
marc n
posted on 7/2/08 at 07:11 PM |
hi finlay
if i can get my hands on another busa to use for a day i can sort you out a setup that is going to be much cheaper
will ask about tomorrow to see if i can borrow an engine
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
finlay
posted on 7/2/08 at 08:31 PM |
excellent
cheers Marc
i will hold off splashing out on the westfield kit for the moment, are you going to machine a casing/bracket out of billit ?
cheers
quote: Originally posted by marc n
hi finlay
cheers
marc
[Edited on 7/2/08 by finlay]
sucksqueezebangblow
posted on 8/2/08 at 09:11 AM |
Hi Marc,
Could you make one for me at the same time?
Clive.
finlay
posted on 19/2/08 at 08:47 AM |
ended up getting the kit from Karl @ extreme engines
also got a 0.625 (5/8) master cylinder insted of the 0.75 i had planned to use
sorted
[Edited on 19/2/08 by finlay]
hardassfunk
posted on 23/2/08 at 01:41 PM |
Bay
Theres one on Ebay at the moment! item number 150219023937
ch1ll1
posted on 23/2/08 at 05:17 PM |
was just about to say the same thing !!
