donut
| posted on 12/2/08 at 07:12 AM |
Multiple opperating systems on same PC- Boot Prob(ish)
I have my sons old pc which has windows XP installed. I have been playing with Linux and installed Linux Mint which is the only OS that boots up. I
also want to install Ubuntu and have a message on startup that lets me choose which OS to use. How do i do this?
Many thanks
Dickyboy
| posted on 12/2/08 at 09:00 AM |
Multiple OS
Not sure if it copes with Linux etc, but the boot.ini file on the root directory directs initiation to whichever choice is selected. and you can have
a default after a settable timeout. There are some good write ups on the internet about the parameters to use. I would strongly suggest backing up the
old boot.ini, it is not for the nervous.
p.s. The boot.ini file is hidden and system, so if you screw up you won't see it if you try to copy back under DOS (if you are FAT32) so suggest
resetting those from Windows before you start.
good luck
joneh
| posted on 12/2/08 at 09:04 AM |
Windows has its own boot program as does Linux. Linux would normally incude grub which is a boot loader. You can install it after if you chose not
to initally.
http://www.gnu.org/software/grub/
hth.
onzarob
| posted on 12/2/08 at 09:24 AM |
Grub is on the ubuntu CD and will look for other os's when your go through the guided install.
| posted on 12/2/08 at 10:45 AM |
You need to run the Mint install program again and install Grub on the MBR of the first hard disc (ie first physical hard disc).
Ubuntu and Mint are really the same Mint comes from the Ubuntu repositories with a couple of extra repositories added for the extra Mint software.
The essential difference apart from the eye candy is that Mint has the windows multimedia codecs & accelerated graphics drivers as part of the
distro, and all the other installed software is tailored for a desk top pc.
Any software that you want from
Ubuntu can be added from vast array of software in the Ubuntu and Mint repositories. In addition Mint has it's own software portal website
http://linuxmint.com/software/?sec=categories&release=2 that installs files directly from the Mint website.
Any cutting edge Debian stuff can also be used if you add extra repositories or you can use sites such as
http://dir.filewatcher.com/d/Debian/i386.0.0.htm to down load the .deb package and just click on the downloaded package to install.
But be aware going outside the official repositories for your distro can cause unforseen problems.
[Edited on 12/2/08 by britishtrident]
donut
| posted on 12/2/08 at 12:08 PM |
Sorry, what the MBR?
Linux Mint is loaded ont the slave hard drive as there was not enough space on the main C/: drive. Will this cause problems?
BTW, I have decided to stick with Mint for the time being as i prefer it to Ubuntu.
Ta
[Edited on 12/2/08 by donut]
onzarob
| posted on 12/2/08 at 12:13 PM |
MBR is the Master Boot Record. Mint/linux can anywhere there is room
| posted on 12/2/08 at 12:49 PM |
I had Windoze and Ubuntu loaded on 2 different drives - GRUB (when installed) comes up with a menu at startup, allowing you to pick the OS you want to
run.
If you've already installed Ubuntu and it boots into it on start-up then you've already got GRUB installed - there's an option in
the Admin menu that allows you to edit the GRUB setup, pick dual-boot, and so on. For example, I had mine set up to show the GRUB menu and if I
didn't pick anything within 5 seconds it would start Ubuntu.
| posted on 12/2/08 at 01:13 PM |
Unless the bios is setup to do differently a PC will always first try boot from the master disc on the first hard disk controller -- many modern pc
motherboards s also have a boot disk select option at boot up (usually press F8 key).
Might be an idea to check the jumper settings on both the drives --- sometimes when combinations of drives from different manufacturers extra
care has to be taken with jumper settings.
