oadamo
posted on 2/3/08 at 12:44 PM |
supercharger running off propshaft
iam fitting the bike engine to my locost but to get the drive to the supercharger off the bike engine is gonna cost. so i was thinking of running a
belt off the propshaft and putting the charger in the passenger foot well. what do you think. should i go for it. will it break the drive spockets or
the bearing in the engine.
adam
Paul TigerB6
posted on 2/3/08 at 12:52 PM |
does the supercharger not need drive related to engine speed rather than road speed as your feed would be taken after the gearbox?? Know little about
superchargers and fuel mapping myself but would imagine you would need 6 fuel maps - one for each gear or am i totally wrong in thinking how
superchargers work??
blakep82
posted on 2/3/08 at 12:53 PM |
the prop shaft speed relates to wheel speed, not engine speed, so i say wrong move
________________________
posted on 2/3/08 at 01:06 PM |
Yup. As already spotted, it ain't going to work
Propshaft rotates relative to road speed not engine speed.....
oadamo
posted on 2/3/08 at 01:15 PM |
bugger this is going to get exspensive. how do they get the drive from the engine then with out all the oil flying everywhere. but if i use the
propshaft i could gear it up or down and use a bypass valve when the boost gets to much hmmmmm.
adam
hardassfunk
posted on 2/3/08 at 01:21 PM |
save some hassle and buy a kit off TTS
http://cgi.ebay.co.uk/KAWASAKI-ZX14-SUPERCHARGER-KIT_W0QQitemZ330194555851QQihZ014QQcategoryZ10490QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQc
mdZViewItem
oadamo
posted on 2/3/08 at 01:25 PM |
mdZViewItem
ive allready got the supercharger. so iam gonna make it fit lol.
adam
NS Dev
extension shaft through either the clutch or generator housing, with an oil seal and housing mounted onto the housing, shouldn't be impossible
and certainly cheap enough
posted on 2/3/08 at 01:33 PM |
The ST1100 has a pulley on the end of the crank which runs the belt to the cam pulleys. That pulley is beyond an oil seal so it's pretty easy to
add a second pulley to run a blower. Presumably chain drived cams will be inside the "oil compartment" and this wouldn't be an
option....
tks
posted on 2/3/08 at 03:13 PM |
or ditch the waterpump and use it as a donor for your parts...
don't know the BHP a waterpump can deliver tough...
Tks
posted on 2/3/08 at 03:55 PM |
Forget any idea about driving it from the propshaft, it's just isn't practical. If you gear it up enough to produce the boost you want in
lower gears, you'll end up overspeeding it in higher gears. The propshaft UJ's will very likely not take kindly to the sideways thrust
required to keep a supercharger belt tensioned.
blakep82
posted on 2/3/08 at 04:08 PM |
here's a mad idea... don't know how or if it could ever work, or if the power it would take to run it would be worth while, but what about
having one driven by an electric motor? you could put it anywhere then.
though it would take a lot of clever electronics to work out a system where the electric motor runs at the same speed as the engine...
daviep
posted on 2/3/08 at 04:27 PM |
Driving a super charger with a motor isn't really practicle. Small super charger probably needs about 15hp @ max speed and boost, that's a
big motor and a big alternator to run it = very heavy. Incidently I think speed control might be the easy bit, I would look into using an ac motor
straight from the alternator (un rectified) as the frequency and hence the motor speed would vary with engine speed.
Completly pointless speculation though
What engine are you fitting your blower too?
Davie
[Edited on 2/3/08 by daviep]
