chrisg
posted on 4/3/08 at 05:05 PM |
remote master cylinder reservoir?
I'm using a twin master cylinder, balance bar brake set-up on my new project, the cylinders don't have a built in reservoir.
I've looked at Demon Thieves amongst others and the reservoirs seem to be very expensive for what they are, could anyone recommend a production
car reservoir that is remote and has two chambers or a single chamber one that I could get two of?
Thank you so very much,
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
tks
posted on 4/3/08 at 06:02 PM |
believe me, you will need a switch incorporated and it needs to be brakefluid closed (so no strange rubber can be used....)
i would def. buy one on a brake system..
in fact its possible that they fail you on that point..
muzchap
posted on 4/3/08 at 06:08 PM |
MNR do a good one (had and sold) for £30.00
Or get 2 master cylinder resovoirs from the scrapyard Get 2 relatively small ones and use those - one for each mastercylinder.
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
turbodisplay
posted on 4/3/08 at 06:13 PM |
I think peugeot do what you are looking for on one of theres cars, 106?.
Not sure but i have a vaguen memory from a scrapyard hunt.
Darren
RazMan
posted on 4/3/08 at 06:59 PM |
CBS do a nice 3 chamber reservoir with switch - so you can cover your clutch too.
Raz
chrisg
posted on 4/3/08 at 08:35 PM |
It's a cable clutch!
Thanks for the replies chaps, I'll trawl the scrappies and let you know what I find.
cheers
Chris
SPYDER
posted on 4/3/08 at 09:26 PM |
Theres one on fleabay right now. Search "SAAB TVR". One day to go. £3 at the moment.
Geoff.
Taz Surfleet
posted on 4/3/08 at 09:53 PM |
arggggggggggggggg spider i got my eye on that !!!lol only kidding
chrisg
posted on 4/3/08 at 10:05 PM |
May the best man win!
(it'll be you, it's looking a bit pricey for me, I've got a reputation as a skinflint to protect! )
cheers
Chris
les g
posted on 4/3/08 at 10:17 PM |
m/cyl res
Chris
hi chris
glad you are up and about
just a thought ,could you use one reservoir and tee the pipe to both m/cyls
les g
muzchap
posted on 4/3/08 at 10:44 PM |
If you can do that - I've got an Elise one you can have for £5 + postage
That has 2 outputs on the resevoir, as it also has a hydraulic clutch!
Let me know via U2U
indykid
posted on 4/3/08 at 10:49 PM |
fiat 126 had remote reservoir from what i remember including float switch
tom
chrisg
posted on 5/3/08 at 11:22 AM |
As I understand it both systems need to be separate so that if one fails you till have some braking, you can use a single reservoir but it must be
divided internally to give two separate chambers - is the Elise one like that?
cheers
Chris
