Author: Subject: CD corrupt? Baby photos lost! Help
Dangle_kt
posted on 31/3/08 at 12:01 PM Reply With Quote
SWMBO has just informed me that the disc I burned the other day holding all the baby pictures is corrupt. I formatted the harddrive after I burned it (due to a new motherboard installation, replacing a faulty one).
Have I lost them? Or is there a way to get the lost files BACK off the cd?
Thanks guys, you could be saving my sex life here! HAHA!
posted on 31/3/08 at 12:05 PM Reply With Quote
It will probably depend on the definition of "corrupt".
It could just be the cdrom's got dusty or oily!!
Is it the same computer? If it's a different computer maybe it'll be okay on the computer that burn it?
Dangle_kt
posted on 31/3/08 at 12:07 PM Reply With Quote
same pc, new motherboard. not dusty or oily - i popped it straight into a case, which she just took it out of.
Mr Whippy
posted on 31/3/08 at 12:08 PM Reply With Quote
my bet is that she put it in upsides down
I have a friend who was amazed to learn that the disk spins
[Edited on 31/3/08 by Mr Whippy]
worX
posted on 31/3/08 at 12:13 PM Reply With Quote
If it were me and something as serious as Baby photos and risk of no sex life, I'd be straight down to the nearest media restoration place in your area!?!
jlparsons
posted on 31/3/08 at 12:14 PM Reply With Quote
Try this software:
CD Data Rescue 2.6
I've used it with reasonable success in the past. Best of luck mate. I have had a couple of nights in the spare room as a result of similar situations...
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
Dangle_kt
posted on 31/3/08 at 12:17 PM Reply With Quote
Yeah I'm thinking data recovery place too. Can't beleive the prices!!!
Anyway next time the computer goes haywire - SHE IS FIXING IT!
RichardK
posted on 31/3/08 at 12:23 PM Reply With Quote
Did you just do the normal xp install format or did you delete the partitions and recreate new partitions and then format that, if it's the first option I may be able to help.
Let me know
Rich
Gallery updated 11/01/2011
Jonte
I saved a friends photos yesterday on his computer. They were gone, no where to be found. But he hadn´t formatted his drive though.
But I used GetDataBack for NTFS 3.3 (his drive was a NTFS partition)
I found the program and unlock file at piratebay.org
Click it
speedyxjs
posted on 31/3/08 at 12:24 PM Reply With Quote
Try it in a different computer before you fork out.
Dangle_kt
posted on 31/3/08 at 12:28 PM Reply With Quote
I'll try it on my laptop when I get in. Then I'll try the program that has been linked to (thanks for that!) then I'll send it off.
I used vista's inbult burning software to make the disc, and I deleted the partition and reformatted twice - due to a cock up! So I am sure there will be next to nothing on the HDD left.
CD recovery for £150 is the best I've found so far.
worX
posted on 31/3/08 at 12:32 PM Reply With Quote
Well I'm not sure I'd be wanting to stretch to 150 notes, but if you do take it somewhere then it's someone else's fault if it doesn't work and you are slightly let off the hook if you know what I mean
RichardK
posted on 31/3/08 at 12:34 PM Reply With Quote
Don't think you'll get anything off the hard drive, my advice would try the cd in as many different brands of cd/dvd drives until hopefully one works, sometimes if the cd recorder is a bit weak and then the reader is also a bit weak it can't read but sometimes a nice new cd reader will just because the laser has a bit more power and this does vary between brands. Hope you get it sorted.
Rich
vinny1275
posted on 31/3/08 at 12:53 PM Reply With Quote
You *might* be able to get something off the drive, depending on the format. If Windows hasn't re-used old areas of the drive, the content of the files might still be there, although their allocation information has gone. There are free disk tools which can find files after a delete / reformat, have a search on the net for them.
There was a disk recovery place I used with work who did recovery on a no win / no fee basis (they weren't successful, but that was cos the heads had been scraping on the disk platters).
Apart from that, you'll have to hope that you can get something off the CD. it is possible - I worked on the Helpdesk at Uni, and one student came in on the day their dissertation was due in, with it on one floppy, which was just chucked into their bag.....
A word to everyone - CDs aren't infallible and they're quite fragile - I wouldn't trust my only copy of something important to one when they cost about 5p to buy - and always verify that they've burned properly and you can read the data off them again.
Good luck, let us know how you get on!
HTH
Vince
bartonp
posted on 31/3/08 at 02:24 PM Reply With Quote
Vince
... ditto, and don't expect data to still be there in 15/20/25 etc years time like good old fashioned photographs (on decent paper). Print 'em out, email them to yourself (Yahoo , GMail etc no limit on size), get some free webspace, etc etc the more copies the better!
geoff shep
posted on 31/3/08 at 03:11 PM Reply With Quote
I've used this to recover files successfully from a CD which I could not read. I think mine was unreadable due to a multisession burning/reading problem but this worked well and is around $30. (The CD recovery software is what you're looking for on the link)
http://www.diskinternals.com/
Jubal
posted on 31/3/08 at 03:16 PM Reply With Quote
Have a go with this before handing over any cash. It's slow but free and if it doesn't work then nothing lost. If you need help please get in touch and I'll try it on one of our many machines at work.
Dangle_kt
posted on 31/3/08 at 03:19 PM Reply With Quote
Thanks for all the offers of help, I will let you all know how I get on tonight.
owelly
posted on 31/3/08 at 05:00 PM Reply With Quote
If all the above fails, just let me know and I can definately help you. I have loads of baby photos and all babies look the same anyway..........
http://www.ppcmag.co.uk
MkIndy7
posted on 31/3/08 at 05:11 PM Reply With Quote
Originally posted by Dangle_kt
I used vista's inbult burning software to make the disc,found so far.
That could well be your problem.. I copied some photo's from a Cannon IXUS 400 memory card onto Vista and it totally corrupted them... they all became stupid sizes like 4GB each!.
I read somewhere that certain JPEG decoders that used to be freely available with Windows XP and all the predecesors weren't available in Vista or you had to pay extra for them.
Good Luck!
RichardK
posted on 31/3/08 at 08:30 PM Reply With Quote
Vista is quite good at corrupting files, their are a few hotfixes for this problem and they have been included in vista sp1 released on the 18/3/08 more info can be found HERE not much help now but may expalin why your files got knackered in the first place.
Hopfully it's just a weak burn though and you'll get them read and dropped onto a disk somehow.
Regards
Rich
Schrodinger
posted on 1/4/08 at 06:38 PM Reply With Quote
You could also try taking the cd into somewhere like Jessops and seeing if it will work in their machines.
BTW the photos aren't still on the camera are they?
[Edited on 1/4/08 by Schrodinger]
Keith
Aviemore
