Author: Subject: Ahhhh - Network set up problems again
Jasper
posted on 9/4/08 at 03:12 PM Reply With Quote
I'm trying to set up a simple Network between two PC's. I use a wireless router to connect them together and connect to the internet. I have run the Network Setup on both machines, called them different names and left the Newtwork name as the default (MSHOME) on both.
I've managed to share the My Docs folder on the new machine no problem, but when I do it on the old machine I get an error message:
'An error occurred when trying to share My Docs. The Server service is not started.'
All I want to do is share the My Docs files on each machine and be able to print from both machines to two printers both connected to the original machine. Not too much to ask!!
Mr Whippy
posted on 9/4/08 at 03:19 PM Reply With Quote
ah ha cought you trying to fix the server!
Jubal
posted on 9/4/08 at 03:23 PM Reply With Quote
The easy way to fix this is to run services.msc (start/run), look for the SERVER service and set it to auto.
Jasper
posted on 9/4/08 at 03:28 PM Reply With Quote
Tried that - didn't work...... thanks though
blakep82
posted on 9/4/08 at 03:29 PM Reply With Quote
its wierd, i spend possibly years trying to do the same thing, then for some reason one day it just worked without me trying.
sorry, but i really don't know why it didn't work before, or what changed to make it work...
________________________
Jubal
posted on 9/4/08 at 04:02 PM Reply With Quote
That's not right. Hmm. You tried on the offending machine I take it? It has to run on both. Is the service started/stopped or what? What happens after a reboot?
Jasper
posted on 9/4/08 at 04:13 PM Reply With Quote
Just managed it, I went into the services and set everything to Auto that related to Networks and Sharing (that seemed sensible) - rebooted the machine and everything is now working.
Thanks for the help
MikeR
posted on 9/4/08 at 04:18 PM Reply With Quote
are you set to run on a domain?
have you tried simple file sharing?
have you sacrificed enough chickens and prayed to Uncle Bill enough?
What OS's are you using?
Jasper
posted on 10/4/08 at 11:22 AM Reply With Quote
Thanks Mike - all sorted now
Lots of bulls sacrificed - worked a treat.
