Taz Surfleet
posted on 25/5/08 at 08:27 AM |
Parallel Prop
Hi Guys how vital is it that the prop runs parallel down the chassis. When MK built my indi chassis it was for an oil cooled GSXR engine, I have
managed to obtain a wc version but have noticed that the sump hangs under the chassis by a good 3" leavin me about 2" of clearance, I can
lift the engine about 2" but that would mean the initial prop to the reverse box is not running parrallel, should I lift the reverse box 2
" as well and have the 2nd prop slightly out, or lift the reverse box 1 " so that the gradient is slightly less all through the run ofthe
prop ?
posted on 25/5/08 at 08:38 AM |
Ideally the propshaft should have a slight tilt on each UJ - roughly 2 or 3 degrees - but the 2 ends should be parallel. Hard to explain in words,
try this picture (it shows a truck transmission, but the idea's the same).
Basically, if a UJ runs absolutely straight the bearings rattle around and damage the housings - brinneling, it's called. A very slight bend
stops this happening. The angle can be side-to-side, up-and-down, or a combination of both.
[Edited on 25/5/08 by David Jenkins]
Taz Surfleet
posted on 25/5/08 at 08:49 AM |
thanks for that David, Ill just raise the engine making sure that the flanges stay @ 90 degrees to each other !
Humbug
posted on 25/5/08 at 09:36 AM |
Don't they need to be at 180 degrees?
Taz Surfleet
posted on 25/5/08 at 10:02 AM |
I stand corrected !!
Paul TigerB6
posted on 25/5/08 at 11:26 AM |
You will probably want to raise the reverse box by around an inch to inch and a half to get then angles on the prop nice as mentioned in the posts
above. Have a play around with it before final fixing to get the UJ angles similar on each prop
