Author: Subject: 13" wheels
joolsmi16
posted on 6/6/08 at 02:22 PM Reply With Quote
13" wheels
Hi all, will 13" wheels fit onto a sierra based front end..
l0c0st
posted on 6/6/08 at 02:36 PM Reply With Quote
They will, it's the rear discs that can cause a problem IIRC.
mcerd1
posted on 6/6/08 at 03:28 PM Reply With Quote
the normal sierra / non ABS ones should be fine (240mm front discs with rear drums)
but I think the 260mm ABS / XR4 type front brakes might be a bit big for 13" as they come with 14" on the Ford and there isn't much space left
either way the hubs are the same - it just depends which brakes you have / want
[Edited on 6/6/08 by mcerd1]
joolsmi16
posted on 6/6/08 at 03:34 PM Reply With Quote
13" wheels
wasn't quite sure if they would fit or not, good to know about the disc diameter.
Jools
mcerd1
posted on 6/6/08 at 03:40 PM Reply With Quote
if you need a set of the smaller front calipers these are the on most mk3/4 escorts as well as the sierra's
RK
posted on 6/6/08 at 04:22 PM Reply With Quote
Check ground clearance too. Newer cars tend to have geometry that favours bigger wheels. I will likely need to go to 15's, at least for my provincial inspection.
smart51
posted on 6/6/08 at 05:09 PM Reply With Quote
Common tyre sizes are 185/60/13. 205/55x/13 for 13" rims and 195/50/15 for 15" rims which are the same outer diameter.
