Author: Subject: wireless internet problems
adam1985
posted on 9/6/08 at 12:32 PM Reply With Quote
have got my pc wired in to the internet router that all works ok but my downstairs pc has wireless internet but sometimes it works sometimes it doesnt the router is the bog standard sky netgear type and is in the room directly above the computer with the problems why does the signal keep coming and going and what can i do to stop it
saigonij
posted on 9/6/08 at 12:34 PM Reply With Quote
have you got a coordless phone or a microwave near? They interfeer.
what card and what type does the pc downstairs have?
vinny1275
posted on 9/6/08 at 12:36 PM Reply With Quote
Could also be the channel that the router is transmitting on has loads of others nearby to compte with. Try changing the transmission channel to see if it gets better...
posted on 9/6/08 at 12:40 PM Reply With Quote
Netgear router usually have a screw on aerial --- try getting a remote one that connects by cable --- usually about 10 quid from Maplin.
If the card in the pc has a screw in aerial you can also do the same at the other end.
adam1985
posted on 9/6/08 at 12:42 PM Reply With Quote
no microwave or fones near it when i brought it it just said wireless compatible have seen a usb wireless adapter but would of thought mine just has that built in it instead how do you change the channel on the router
posted on 9/6/08 at 12:51 PM Reply With Quote
I have had a similar problem with Netgear stuff. I now have a few devices setup, Wii and 2 laptops all with excellent signal and internet connection.
Set wireless channel to 11 using g+b mode. This is quick enough for video etc., you dont need the 108Mbps rate as it drops out more often.
Despite hating this router for a few years I have found these settings to be easily the most reliable to a point where it is faultless. Oh and I have my mobile and wireless home phone near it...
To alter channel go to wireless settings its in the top section.
adam1985
posted on 9/6/08 at 01:56 PM Reply With Quote
there is nothing on the router to change the channel but on the bottom theres a sticker which says channel 11 have had a look on my computer too and there is no aerial connection on that
Jubal
posted on 9/6/08 at 02:11 PM Reply With Quote
The Sky router firmware is crippled and I can't remember if you can change the channel. If you know what you are doing then the following is useful:
http://www.skyuser.co.uk/forum/technical-discussion/1199-ive-done-flashed-router-got-my-sky-password.html
