Author: Subject: how to use a pc
eccsmk
posted on 10/6/08 at 01:31 PM Reply With Quote
how to use a pc
where can i learn
a) what all these technical terms mean
b) how to use my pc fully
i can use the internet and i do a bit of invoicing and a few quotations but thats it im stuck on anything more complicated i cant even type with more than my two index fingers
yes i am a tad thick when it comes to computers
look at my post count woooo
[Edited on 10/6/08 by eccsmk]
bartonp
posted on 10/6/08 at 01:41 PM Reply With Quote
Might want to try a local evening class ...
Agriv8
posted on 10/6/08 at 01:51 PM Reply With Quote
local library may do somthing or evening course or a local college.
If you are wanting to get a bit of paper the 'Claits' ( if it is still going isnt bad )
I have always used the 'dummies' books looking arround my desk I have 2 at the moment
Unix For Dummies and Visual Basic .NET fo r Dummies ( 7 volumes in 1 !!! ) but must have arround 5 to 50 of these and found them all very good.
I am sure they will do an intro into computers but look for somthing that is bassed around your operating system ( probably XP ).
Oh in answer to your actual questions
a) You never will as they change as soon as you lern them.
b) you never will, you will only learn to get on with it. It may save you time but it will always ensure that at the worst moment it will cause you more trouble and strife than its worth.
Ps I have been working with PC's for 19 years and there are still thing that confuse me.
PS ia m only up to 4 fingure tying and a thumb !!!
regards
Agriv8
worX
posted on 10/6/08 at 01:56 PM Reply With Quote
I'm pretty useless on computers too, just picking up stuff where I can with advice form here and friends.
There may be a couple of ways you can learn though.
The F1 Key is generally considered the HELP Key. For example if you are in the MS Word program then you can hit F1 and then allows you to type something into the Index and that will list all the things in relation to the words you typed.
You could also try typing the phrase you are struggling with into Google.
Or if you really want to learn then you could search Google for Step by Step lessons on certain programs. This has a specific name and for the life of me I cannot remember what it is called!
HTH
Jeebus, I've remembered it - A Tutorial - I've no idea why I couldn't think of it before as it's not even limited to help with PC guidance - it's just a bloody tutorial
[Edited on 10/6/08 by worX]
mookaloid
posted on 10/6/08 at 02:55 PM Reply With Quote
Just ask on here when you need to know something - that's what I do - never failed yet
Jubal
posted on 10/6/08 at 03:05 PM Reply With Quote
It takes a "special" sort of person to want to learn to use a computer for the sake of it. Following on from the others however, if you have a specific requirement and are prepared to research (books, help and google in particular) then there is almost NOTHING you cannot accomplish these days. You'll have to put the work in but someone will have done it, blogged about it and it can be found on google.
Davey D
posted on 10/6/08 at 03:41 PM Reply With Quote
working in IT, the thing i always tell people to do is just have a play.Llook around at things.... dont be scared to run those programs youve never run before.
you wont learn everything from books... you need to get stuck in and use it in a real world environment, then when/if you get stuck look up the bits you need
eccsmk
posted on 10/6/08 at 06:13 PM Reply With Quote
thank you folks
ive actually noted down what has been written here
i started doing i.t. at school but never carried on with it
i think i may end up with a job in it if possible due to my health mainly
the scary thing is im only 26
again thank you all for your input
