New Topic New Reply
Author: Subject: how tight
Stuart_B
posted on 18/6/08 at 06:45 PM Reply With Quote
how tight
hi all, i throught i have done all my wisbones and shocks now, but know i am thinking how tight do you do the bolts??
do you make it crush tight or tight but lose enough so it moves freely?
thanks
stuart
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 18/6/08 at 07:00 PM Reply With Quote
30lb/ft on my westfield for all the w/bone and shock bolts i think.
[Edited on 18/6/08 by CRAIGR]
l0c0st
posted on 18/6/08 at 07:10 PM Reply With Quote
Hi, I have read on here before that it needs to be on all four wheels before tightening them up fully. I can't remember why, but someone will be along soon to confirm it's correct.
Thought I should mention it, just in case
Dom
mookaloid
posted on 18/6/08 at 07:16 PM Reply With Quote
Dom
I think that's if you are using the Truimph Herald rubber type bushes - the indy bushes are PU and are not fixed to the centre crush tube like the herald ones.
Mark
RichardK
posted on 18/6/08 at 08:24 PM Reply With Quote
Yep if you're using the Truimph Herald type on which the crush tube is fixed then yes keep them slack, sort out the ride height etc and tighten them up, thats what I've done anyway.
Rich
P.S Mooky you still working too hard?
Gallery updated 11/01/2011
posted on 18/6/08 at 08:26 PM Reply With Quote
If using the usual poly bushes and steel crush tube then the bolts can be done up with the car in air and wishbones at any angle. Do them up good and tight as you want to hold the crush tube nice and tight in the chasis bracket and ensure that it's the bush rotating on a fixed crush tube.
Make sure you grease the bush/tube interface whilst assembling otherwise they will suffer stction and squeak like a bugger forever more.
For the shock bolts, unless you're using shocks with rod end type fittings, you want to wait until the car is on it's wheels with the full weight acting on it and the ride height roughly set. then pinch the bolts up tight. This avoids over stressing the metal/rubber bond of the metalstic bushes of the shocks.
HTH
Nick
flak monkey
posted on 19/6/08 at 06:47 AM Reply With Quote
Thats the right torque for rubber bushes. Polybushes need to be done up to around double that to be sure of holding the crush tube tight in the brackets.
The recommended torque variues depending on the bolt, but will take it to ~75% of its yeild strength, this is the point at which it produces the optimum clamping force.
For an 8.8 grade M12 this is approx 100Nm
Sera
http://www.motosera.com
New Topic New Reply
