Author: Subject: XP Service Pack 3
mookaloid
posted on 26/6/08 at 09:14 PM Reply With Quote
XP Service Pack 3
Anyone got any thoughts on installing this? Has anyone tried it and had problems? Do we really need it? etc etc
Mark
RichardK
posted on 26/6/08 at 09:24 PM Reply With Quote
If your machine is fully up to date then not neccesary, it's useful when doing a clean xp install, they had to do something when alot of people decided to use the vista downgrade cd's! and the update server was getting hammered so they rolled up all the updates into one.
Regard
R
P.S You ok haven't heard from you for a while.
Gallery updated 11/01/2011
stevebubs
posted on 26/6/08 at 09:31 PM Reply With Quote
Ditto. I have a slipstream SP3 CD I use to install my PCs when they need it.
Ivan
posted on 27/6/08 at 07:08 AM Reply With Quote
I read somewhere that SP 3 improves the speed of XP by something like 30% - don't know if its true though as haven't tried it.
bimbleuk
posted on 27/6/08 at 07:20 AM Reply With Quote
Not from what I've seen if anything it adds a few more startup services and lengthens the boot process. Though you can disable these. There are some minor improvements in it but by far the biggest benefit is when doing a clean install.
mcerd1
posted on 27/6/08 at 07:48 AM Reply With Quote
I've put it on my machines, some where fully upto date before hand, some where missing 6 - 12 months worth of updates
so far I've noticed no real difference on any of them
second the comments about clean install's - the last one I did had about 150 updates to download after a clean sp2 install
[Edited on 27/6/08 by mcerd1]
tegwin
posted on 27/6/08 at 10:22 AM Reply With Quote
Some MS software wont run on anything less than SP3....(Bizare sys admin tools etc)...
On some machines you have to install the MS .Net framework files first otherwise the sp3 installation fails....
www.verticalhorizonsmedia.tv
mad-butcher
posted on 1/7/08 at 06:22 PM Reply With Quote
there is a bug in sp3 which prevents any further security updates, but it's any easy fix,
Tony
heres the fix
cheers guys found the cure
http;/forums.microsoft.com/TechNet/ShowPost.aspx?PostID=3308206&SiteID=17
just go to c:\windows\system32 and find and register wups2.dll
to do that,right click on it and select open with then Choose Program and find
c;\windows\system32\regsvr32
if you choose to 'always use the selected program to open this type of file' then all you will have to do is double click on any dll to register it
once you have registered Wups2 all your problems will disappear
Thanks to a Gary o'Connor on that site for the info above
NOTE: this is only for the problem of XP with SP3 not installing updates.
Tony
[Edited on 1/7/08 by mad-butcher]
