Author: Subject: Computer Help Needed
Guinness
posted on 11/7/08 at 10:14 AM Reply With Quote
Last night I tried removing a few programmes from my home computer that I don't use anymore (the ones that came free with the computer but the trial licences have expired).
Trouble is, something went wrong! Started the computer this morning, and I get a constant window popping up.
It is the Windows Installer window, which auto starts to configure "Roxio Media or Music Manager"
It comes back that it can't find the file, with an option box to "Cancel" which when pressed starts the whole thing off again. After about 5 mins of this I get another box popping up, saying "Microsoft.net" is missing something. And I can't close that down either!
Any help gratefully received!
Mike
Mr Whippy
posted on 11/7/08 at 10:21 AM Reply With Quote
I recommend the window, open it first mind
posted on 11/7/08 at 10:56 AM Reply With Quote
Did you use add/remove programs to take them off? It should use their uninstaller and remove all the registry entries. If they are still in startup you can use msconfig from the run menu to stop them loading at startup.
contaminated
posted on 11/7/08 at 12:16 PM Reply With Quote
Try using a system restore point or download a free regsitry cleaner from the internet.
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
Mr Whippy
posted on 11/7/08 at 12:20 PM Reply With Quote
cheers I need this too
Worzey
posted on 11/7/08 at 12:38 PM Reply With Quote
Did you remove the .Net framework?
Most modern applications require this to run correctly.
You can download a new version from the Microsoft website and install and this could resolve the problem.
Caterham R400
chrism
posted on 11/7/08 at 05:08 PM Reply With Quote
.NET framework can also be installed from the windows update website if you choose the custom option.
A little hard work never killed anyone, but why take the risk!
