Avoneer
| posted on 5/8/08 at 07:56 PM |
Video Controller (VGA Compatible)
Still got an exclamation mark in device manager after a re-boot.
Can someone point me in the rigth direction.
Ta,
Pat...
joneh
| posted on 5/8/08 at 07:59 PM |
Try updating drivers?
Avoneer
| posted on 5/8/08 at 08:06 PM |
Won't connect to the internet to do that.
Pat...
joneh
| posted on 5/8/08 at 08:11 PM |
Download the driver on the PC you're on now, burn to CD, etc
Avoneer
| posted on 5/8/08 at 08:20 PM |
Which driver?
I don't know what's missing.
Pat...
Avoneer
Which driver?
Pat...
Avoneer
| posted on 5/8/08 at 08:21 PM |
Which driver?
Pat...
| posted on 5/8/08 at 08:30 PM |
You need to find out what graphics processor your PC uses, e.g. NVidia, ATi, S3, Intel etc. and download the appropriate drivers.
If you have a separate graphics card, e.g. AGP or PCI express then you should be able to take it out and chances are the PCB will have some form of
identification on it. If your motherboard has integrated graphics then (if chipset is not obvious) you'll need to find manufacturer and model
number and look up which chipset it uses.
Avoneer
| posted on 5/8/08 at 08:38 PM |
Yep - MB has integrated graphics.
Does this Everest print help:
Motherboard:
CPU Type Intel Pentium 4, 2400 MHz (18 x 133)
Motherboard Name Jetway 848PDC(P) (5 PCI, 1 AGP, 2 DDR DIMM, Audio, LAN)
Motherboard Chipset Intel Breeds Hill i848P
System Memory 240 MB (PC3200 DDR SDRAM)
DIMM1: Nanya M2U25664DS88B3G-5T 256 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133
MHz)
BIOS Type Award (07/06/04)
Communication Port Communications Port (COM1)
Display:
Video Adapter Intel Extreme Graphics 2
3D Accelerator Intel Extreme Graphics 2
Multimedia:
Audio Adapter Realtek ALC655 @ Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3]
Storage:
IDE Controller Intel(R) 82801EB Ultra ATA Storage Controllers
Floppy Drive Floppy disk drive
Disk Drive HDT722516DLA380 (160 GB, 7200 RPM, SATA-II)
Optical Drive _NEC DVD+RW ND-1100A (DVD:4x/2.4x/12x, CD:16x/10x/40x DVD+RW)
SMART Hard Disks Status OK
MkIndy7
| posted on 5/8/08 at 08:51 PM |
Presuming it had the drivers before can it not find them again automatically if you just tell it to update the drivers?.
If not in the update part you should be able to direct it ot where the drivers are, they should be in a folder called
C:/windows/system
or c:/windows/system32
or any recovery Cd's that came with it.
joneh
| posted on 5/8/08 at 08:53 PM |
Waht make is the mobo?
Avoneer
| posted on 5/8/08 at 09:06 PM |
Nope - no recovery CD and managed to loose all the drivers when I formatted.
MB is a Jetway 848PDC(P)
Pat...
| posted on 5/8/08 at 09:19 PM |
Pat - why did you format not having any means of re-installing drivers...? :/
Dont you have a Windowz CD anywhere?
McLannahan
| posted on 5/8/08 at 09:21 PM |
Pat - Drivers are all here for your motherboard.
Select Drivers on left hand side
http://www.jetway.com.tw/jw/motherboard_view.asp?productid=134
&proname=848PDA#
stevebubs
| posted on 5/8/08 at 09:23 PM |
Motherboard Manual...
| posted on 6/8/08 at 09:29 AM |
Pat...
Which is very odd since the 848P chipset does not support onboard video (and most certainly not Extreme Graphics 2 which is only found on much newer
chipsets). None of the references I have seen to this board mention on board video either.
Jetway don't even list the board on their website; the links provided by others are for the 848PDA. It may well be an OEM variant that was
never sold separately.
Does it look like this? http://hard.zol.com.cn/2004/0305/images/139848.jpg
mcerd1
| posted on 6/8/08 at 10:52 AM |
that sound about right to me, I get alot of that with HP's and Packardbell's that I'm asked to look at
who makes the PC ?
do they have drivers on there website ?
[Edited on 6/8/08 by mcerd1]
Avoneer
| posted on 6/8/08 at 06:57 PM |
Nope - its like the Bitsablade was!
Is it time to open her up and write down everything I see?
Pat...
mcerd1
| posted on 7/8/08 at 08:32 AM |
if your really lucky then the MB will have a model number writen on it
write down what you see on the very first screen when you turn it on (the one that only stays on for a second or 2)
or you might get it from the BIOS setup (press: del, F2, F10 or what ever its says for setup when you first turn it on - just don't save any
changes)
there should be a big long code (called the bios string)
there are ID tools on various websites that will decoce it and tell you what you've got
failing that there are some ID tools that work with the serial numbers (normally a sticker on the MB somewhere - often on, or near the PCI slots)
