nib1980
| posted on 14/8/08 at 08:30 PM |
Internet acess numpty question
Hello All,
I recently formatted the PC Don't ask I was having a moment of inspiration.
anyway got the OS back on and couldn't find the Modem CD, so plugged it in, and it worked and is connecting me to the net? has it stored all
the logon details inside it or something? It's a Belkin G+ mimo wireless router and modem.
I'm a bit of a numpty, and i'm worried i'm connecting to the net some other way and it'll cost me a fortune, but i can't
see how as i've not given any details to anything?
help and reassurance needed.
Many thanks
RichardK
| posted on 14/8/08 at 08:42 PM |
All the settings will be on the router itself and the network port probably the wireless card on your pc will be set to automatically get an ip
address from the router probably so yep everything should be ok.
Did you connect to your wireless network at any time and enter in your encryption key?
Or have you a network cable going from the router into the network socket on the pc even though it a wireless router, either way you're fine!
Regards
Rich
[Edited on 14/8/08 by RichardK]
Gallery updated 11/01/2011
nib1980
| posted on 14/8/08 at 08:50 PM |
nope i just plugged it in and connected to the Net. it's the only cable that is connected, so must be going through the router i guess
RichardK
| posted on 14/8/08 at 08:53 PM |
Just updated my earlier post, yep thats fine, I prefer mine on the wire. seems a bit more reliable.
Rich
| posted on 15/8/08 at 02:00 AM |
If you have a Cable or ADSL connection the router stores all the WLAN connection information (i.e. the connection between the modem and the
exchange).
Presumably you have an Ethernet connection between your PC and the router. As Windows detected an Ethernet card during installation it automatically
set it up to use DHCP. Since Cable/ADSL routers almost always have DHCP servers built in you rarely need to manually configure any IP settings.
