Rob Lane
| posted on 17/8/08 at 11:42 AM |
Fixed IP and camera with BT Biz Hub
I'm getting a bit fed up with this now. I'm quite computer savvy but this problem has me stumped.
BT Biz Hub. I have 5 fixed WAN IPs.
I have a camera server on a LAN.
Now, I've left the hub as Dynamic IP on WAN and attempted to port forward the firewall ports 80 and 4321 for the camera.
It won't work. It seems to allow it in menu but not actually open the ports associated with the camera on the LAN.
Using the WAN address it will not access the camera from a remote location.
Second I tried allocating a fixed WAN IP to the hub. It will not accept the address and claims it is invalid. Even BT can't help here.
Seems I have 5 addresses for nothing with this hub. Don't want to change the hub as it's performance is excellent both on line and
wireless.
It's the latest HGV2700. There is no help on a search of net.
Any ideas anyone?
[Edited on 17/8/08 by Rob Lane]
ecosse
| posted on 17/8/08 at 12:01 PM |
More questions than answers at the moment, but, I take it you are trying to access the camera from the WAN to your LAN?
What subnet mask are you using when you try and assign a fixed IP to the WAN interface of the router?
How do you assign LAN IP's, i.e. via DHCP off the router?
Are you sure you are trying to connect to the correct WAN IP (sorry, had to ask )
Is the router also setup to filter outgoing traffic (may be blocking the cam return packet requests?)
I'm not familiar with that router, but does it have a DMZ capability?
If so you could stick the cam on the DMZ with one of your external IP's and access it that way?
Alex
Ivan
| posted on 17/8/08 at 12:38 PM |
Geeks
Must be because I didn't understand a word of either postings.
But then again you can't be because you are on this forum after all
I'm confused - which are you?
[Edited on 17/8/08 by Ivan]
Rob Lane
| posted on 17/8/08 at 12:58 PM |
Yes, trying to access camera from WAN.
Subnet is 255.255.255.0
Reading rest of post.
LAN ip from router range, set at -.-.-.100
and set as fixed on LAN.
Yes right WAN IP, the router always displays this fortunately.
Not thought of outgoing filtering ! Will check to-morrow. I'm at remote location now, not at router site.
Didn't want to set up DMZ as yet till I can figure out how it should be normally.
I now think that I have this all wrong somehow. I am correct in assuming I can set one of the fixed IPs as the Public (WAN)IP on the router. i.e. a
static public IP?
Rob Lane
| posted on 17/8/08 at 01:04 PM |
Ivan,
it's all just acronyms, I don't know what I'm on about, it's a bluff
Rob
the_fbi
| posted on 17/8/08 at 02:04 PM |
On our BT setup with 5 statics, you get 1 IP for the ADSL router, then a group of 5 (totally different to the router one) for your statics.
If you setup your IP camera to be one of your static IPs, you shouldn't need any port forwarding at all, as effectively the camera will sit on
the public IP. You will however need to unblock the ports it accepts incoming connections on.
You'll then just access it from the WAN side using its (one of the 5 static) IP.
ecosse
| posted on 17/8/08 at 02:40 PM |
static public IP?
The problem is your subnet mask, for you to have an allocated range if IP's you need a custumised subnet i.e. 255.255.255.248
You can set and use any of your allocated IP's, but only with the correct subnet mask or it won't work.
I am guessing that your mask is .248 by the IP range you have, but you should be able to see this when the router DHCP's it's IP, go to
"status" and check though.
Hope this helps a bit
Alex
PS
Ivan - both
joneh
| posted on 17/8/08 at 04:27 PM |
If you need any recording software give me a shout.
My Home Setup
Rob Lane
| posted on 18/8/08 at 03:41 PM |
Thanks all.
I gave up on the firewall ports and the fixed IP.
I've set it in DMZ mode and allowed dhcp and it has allocated the WAN IP to it and set it's own firewall rules for other computers.
I can even access it on my mobile
Just have to track it for a while to check it doesn't change the public IP often.
Rob Lane
| posted on 19/8/08 at 08:47 AM |
Arghhhh, can't believe it
Wife was viewing camera remotely before I set off back and all was OK.
Get home and the damn thing will not show now.
Checked this morning with the camera location and nothing has changed. All settings the same and they can watch the camera locally using the WAN IP
address.
DMZ is on, IP is allocated, firewall is open,
camera has same ip, so why no connection ?
RoadkillUK
| posted on 19/8/08 at 11:35 AM |
Get orf my Land <-- Link
I have one of them too, caught me a couple of thieving b'stards.
joneh, any idea why you get such a good FPS? Mine is terrible and my other camera (not shown) is more like 3 secs a frame!
This is pic from Yesterday (18th) of some thieving pikey, not content with the scrap I left him (back of locost) he routes around the back yard, and
takes my Trolley Jack.
I caught him up about 1/2 hour later and took my stuff back.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Rob Lane
| posted on 19/8/08 at 06:10 PM |
OK, now I'm baffled.
My own browser will not show anything but on my WAP enabled phone I can access it
Someone please try 81.136.28.199 and see if a password request screen pops up.
RoadkillUK
| posted on 19/8/08 at 06:33 PM |
Hi Rob, just tried it for you and a window opens up for a username and password.
[Edited on 19/8/08 by RoadkillUK]
Roadkill - Lee
www.bradford7.co.uk
Rob Lane
| posted on 19/8/08 at 08:07 PM |
Well I found what is wrong but can't figure out what it is.
The security log in my router here shows the IP blocked as Black List(e)
But what is blocking it ? Norton Security ? or router firewall ?
Router does not seem to have an 'allow site' feature, unless I'm missing it.
Same for Norton, I can't find it in that either.
Helpppp
Rob Lane
| posted on 19/8/08 at 08:34 PM |
It's the router. I tried another computer on my network which doesn't have anti virus (it's not normally on network) and the router
still logs the acces as Black List.
Rob Lane
| posted on 20/8/08 at 10:27 AM |
OK I've given in.
During the night the camera crashed the biz network.
I had to remove it this morning to get the network back to normal.
Don't buy an Edimax IP camera with built in server
