2008 Fireblade engine height
fege - 3/8/13 at 07:12 AM
I'm thinking of swapping my carbed R1 engine for a 2008 Fireblade lump. The Honda seems a bit high with the stadard airbox fitted. Doesanybody know how to make it a bit lower or sybbly measurements of the stock setup?
SausageArm - 3/8/13 at 08:55 AM
Buy a billet sump from AB Performance, that'll help with ground clearance, as it's about 100mm shorter than the standard sump.
Then make a new inlet manifold like my friend did, here are some photos with the panel air filter removed.
