Gsxr 1000 rapid bike 3 ecu tuning
GOJO - 3/3/13 at 01:33 PM
Rapid bike 3 by dim sport very similar to power commander but better in my opinion
The ecu stands alone and the wiring harness for the engine plugs in so basically the unit can be fitted onto something else say a honda or kawasaki with a loom(about £70)
Whats is it ? Adjustable fuelling via lap top , adjustable ignition timing via lap top , a cordona quickshifter can be plugged straight in and the unit kills the coils and injectors , adjustable kill time for each gear via lap top, switch mapping (switch included)
The unit has a loom for gsxr 1000 k5k6 and currently has mapping for a stock blue printed motor using a k&n and full yoshimura system with this on the bike it dyno'd at 177bhp
So this is a pc3 a pc ignition module and a pc hub in one unit
Im looking for £200 posted
A cordona pull/push qs sensor is about 130 the beauty of them is you can weight the sensor so you dont get false kills and it works push together or pull apart to activate it.
Cheers joe 07855369369
