Zetec cams
oliwb - 25/11/06 at 05:03 PM
Anyone know if these would fit a 2L as well???
http://cgi.ebay.co.uk/RS-1800-130-spec-zetec-cams-escort-fiesta-ford_W0QQitemZ120055884228QQihZ002QQcategoryZ21654QQrdZ1QQcmdZViewItem
Oli.
big_wasa - 25/11/06 at 05:07 PM
Yep but a waste of time and money as the 2l spec are meant to be a close match to them.
[Edited on 25/11/06 by big_wasa]
cct7kitcars - 25/11/06 at 05:12 PM
would these fit a 1600 zetec
oliwb - 25/11/06 at 07:56 PM
Do black top cams fit on a silvertop zetec?? My engines a 130K miler and I'm planning on a full re-build so some newer even standard cams would be good on it.....Cheers Oli.
PS.
I take it that the 130 hp spec cams are just standard cams???
JackNco - 25/11/06 at 08:26 PM
im not sure but at a guess no. apparently the pistons are spaced differently
Schrodinger - 26/11/06 at 12:10 PM
The black top uses mechanical followers the silver top uses hydraulic followers and so the profiles are different and so you shouldn't use the black top cam on a silvertop without replacing the followers with mechanical followers.
