Have a coal effect gas fire that I want to sack and fit a dirty, dusty high maintenance coal/wood fire.
Current fire is a steel box lined with moulded ceramic fibre insulation with a freestanding gas burner
stacked with 'coal'. In front is a decorative cast iron fender.
So can I replace the burner with a dog grate with ash pan and retain the rest or will the entire box
have to come out to reveal some ugly brickwork ?
The top of the box is open and there is no flue liner (was an open fire when house built and I bought
a gas one that needed no liner).
Obviously I want the Locost but safe option
I could put a log stove in the ugly hole and line the flue but would rather have an open fire.
Hi
Last summer I did the opposite. Solid fuel to LPG
Pic below shows my late 70's build....
And then the mess
(they tell me early 70's wallpaper is coming back)
And today...
What do you call a dog grate? Square free standing jobbie, or a fitted tapered one with curved front?
Paul G
Ideally a fitted tapered one retaining the cast spiky fender similar to your first two pics.
normally the box has to come out too and the gas pipe needs capping back to a safe place by someone who can do it it safely
the two main options for the box is either a concrete chair brick or a cast iron stove the burner box for your gas fire is only thin so will distort
very quickly with the heat and will rot very fast do to soot being acidic (sulphuric acid) i think it is
[Edited on 4/1/09 by adam1985]
Cheers guys,
fair point about the thin metal distorting.
Paul, there is a lintel from when it was an open fire, so I'll get a few fire bricks and knock something up.
Cheers guys,
