Don't know how true these are but provide nice reading while you have your morning coffee......
Fun Historical Tidbits
Historical tidbits you didn't know you needed to know!
In George Washington's days, there were no cameras. One's image was either sculpted or painted. Some paintings of George Washington showed
him standing behind a desk with one arm behind his back while others showed both legs and both arms. Prices charged by painters were not based on how
many people were to be painted, but by how many limbs were to be painted. Arms and legs are "limbs," therefore painting them would cost the
buyer more. Hence the _expression, "Okay, but it'll cost you an arm and a leg."
As incredible as it sounds, men and women took baths only twice a year (May and October)! Women kept their hair covered, while men shaved their heads
(because of lice and bugs) and wore wigs. Wealthy men could afford good wigs mad e from wool. They couldn't wash the wigs, so to clean them they
would carve out a loaf of bread, put the wig in the shell, and bake it for 30 minutes The heat would make the wig big and fluffy, hence the term
"big wig." Today we often use the term "here comes the Big Wig" because someone appears to be or is powerful and wealthy.
In the late 1700s, many houses consisted of a large room with only one chair.Commonly, a long wide board folded down from the wall, and was used for
dining. The "head of the household" always sat in the chair while everyone else ate sitting on the floor Occasionally a guest, who was
usually a man, would be invited to sit in this chair during a meal. To sit in the chair meant you were important and in charge. They called the one
sitting in the chair the "chair man." Today in business, we use the expression or title "Chairman" or "Chairman of the
Board."
Personal hygiene left much room for improvement. As a result, many women and men had developed acne scars by adulthood. The women would spread
bee's wax over their facial skin to smooth out their complexions When they were speaking to each other, if a woman began to stare at another
woman's face she was told, "mind your own bee's wax." Should the woman smile, the wax would crack, hence the term "crack a
smile" In addition, when they sat too close to the fire, the wax would melt . . . therefore, the expression "losing face."
Ladies wore corsets, which would lace up in the front. A proper and dignified woman, as in "straight laced". . . wore a tightly tied
lace.
Common entertainment included playing cards. However, there was a tax levied when purchasing playing cards but only applicable to the "Ace of
Spades." To avoid paying the tax, people would purchase 51 cards instead.
Yet, since most games require 52 cards, these people were thought to be stupid or dumb because they weren't "playing with a full
deck."
Early politicians required feedback from the public to determine what the people considered important. Since there were no telephones, TV's or
radios, the politicians sent their assistants to local taverns, pubs, and bars. They were told to "go sip some ale" and listen to
people's conversations and political concerns. Many assistants were dispatched at different times. "You go sip here" and "You go
sip there." The two words "go sip" were eventually combined when referring to the local opinion and, thus we have the term
"gossip."
At local taverns, pubs, and bars, people drank from pint and quart-sized containers. A bar maid's job was to keep an eye on the customers and
keep the drinks coming. She had to pay close attention and remember who was drinking in "pints" and who was drinking in "quarts,"
hence the term "minding your "P's and Q's "
One more: bet you didn't know this!
In the heyday of sailing ships, all war ships and many freighters carried iron cannons. Those cannons fired round iron cannon balls. It was necessary
to keep a good supply near the cannon. However, how to prevent them from rolling about the deck? The best storage method devised was a square-based
pyramid with one ball on top, resting on four resting on nine, which rested on sixteen. Thus, a supply of 30 cannon balls could be stacked in a small
area right next to the cannon. There was only one problem...how to prevent the bottom layer from sliding or rolling from under the others. The
solution was a metal plate called a "Monkey" with 16 round indentations.
However, if this plate were made of iron, the iron balls would quickly rust to it. The solution to the rusting problem was to make "Brass
Monkeys." Few landlubbers realize that brass contracts much more and much faster than iron when chilled. Consequently, when the temperature
dropped too far, the brass indentations would shrink so much that the iron cannonballs would come right off the monkey. Thus, it was quite literally,
"Cold enough to freeze the balls off a brass monkey." (All this time, you thought that was an improper expression, didn't you.)
I think most of those explanations were made up to fit the words, rather than the other way round... but it filled a tea-break!
As an example, this is what a literary bod makes of brass monkeys:
World Wide Words
amusing as they, I am not convinced any of those are genuine.
the brass monkey cannon balls is definetley not trye.
the P's and Q's I heard was to do with printing in the that letter stamps are in reverse.
Also has anyone ever seen a quart beer glass in a museum? no, didn't think so.
Yes - P's & Q's is from printing - it's easy to pick out the wrong one when selecting type from the lower-case boxes.
