HOME REMEDIES
timf - 7/1/05 at 04:03 PM
1. If you are choking on an ice cube, don't panic. Simply pour a cup of boiling water down your throat and presto! The blockage will be almost instantly removed.
2. Clumsy? Avoid cutting yourself while slicing vegetables by getting someone else to hold them while you chop away.
3. Avoid arguments with the Mrs. about lifting the toilet seat by simply using the sink.
4. For high blood pressure sufferers: just cut yourself and bleed for a few minutes, thus reducing the pressure in your veins.
5. A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives, then you will be afraid to cough.
7. Have a bad toothache? Smash your thumb with a hammer and you will forget about the toothache.
Sometimes, we just need to remember what the rules of life really are: You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Remember: Everyone seems normal until you get to know them.
Never pass up an opportunity to go to the bathroom.
If you woke up breathing, congratulations! You get another chance.
And finally, be really nice to your family and friends, you never know when you might need them to empty your bedpan.
And never forget to smile...your smile may be the only one that someone else gets to see today.
JoelP - 7/1/05 at 07:36 PM
some classics there tim
David Jenkins - 9/1/05 at 08:35 PM
One of those reminded me of something one of Billy Connell's friends told him when he passed 60...
...three things to remember:
1. Never miss an opportunity to have a pee.
2. Never trust a fart.
3. If you find yourself with an erection, use it. Even if you're alone.
