I'm trying to dial in my suspension, and all of the coilovers I've worked with have been on cars....and these are fairly different.
specs:
-Inboard front
-Miata donor
-195/50/15 tires (R888's)
-goal: front lower control arms level w/ ground and Rear about 10mm higher than front.
Questions:
1) The lower spring perches only have 1 collar...does the weight of the car keep that in place? (I've always had 2 collars, that can be
tightened to each other to lock in the height)
2) To get my rear low enough, the spring collar is threaded so far down that when the car is on jack stands, the springs are loose. Is this ok?
(I've seen other car coilovers that use "spring helpers"...basically a 2nd thin spring that doesn't add any force, but takes up
the slack when the car is on jack stands)
coilover w/ spring helper:
here's a pic of the front coils...this is how my rear look to get the right height (the spring is loose)
Cheers!
I remember mine feeling a bit loose but the weight soon takes care of that and all of them only have one spring i guess due to the short length
mine have a grub screw in them to keep them in place
on the back of mine if i have it on axle stands the springs drop from the top cup. once it is dropped to ground though they always relocate with an un-nerving twang noise :-)
Thank god its not just me!! I had planned to get to the bottom of this problem tomorrow by removing most of the suspension and checking I hadn't
got all the springs/shocks the wrong way around. Thats saved a job, but doesn't answer why this happens? Surely a shorter damper body should be
used. Seems a little half arsed. Unless someone can explain the benefit of your wheels dropping in this manner when in the air?
Lee
its normal - never known a colar move and as the do not rotate ( as the are bolterd into the mounting bracket) there is little roational force on
them. They locate them selves very well when dropped to the ground though the first few times you get a big "Twang" as the seat will make
you Jump
Ps the dampers are the length they are due to availability and cost a better I belive also sring strength and length is a factor. though the main
reason is to save weight as the same basic chassis are used for the EC boys where shaving every Ounce is important.
hope that helps ATB
Agriv8
[Edited on 24/5/11 by Agriv8]
Thanks for the info. Still sounds a bit iffy though. So when the car is "light" ie over a bump or hump back bridge ( in the extreme) then
you have no suspension provided by the spring, it looks like the damper is too long or the spring too short.
Lee
If the spring is slack then definitely get some helper springs in there, or a shorter spring.
Hi
The spring length on that first pic can't possibly be right. The spring is wound up towards the top end of its height adjustment. When the car is
sat at static ride height the damper would only have 25 ish mm before siting on the bump stops. There is absolutely no room for movement in droop
before the spring is unloaded.
It's quite common for the spring to become unloaded at full droop of the damper IE when the car is on a jack out of normal working range. But to
have no load in the slightest of droop travel is ridiculous. Something is wrong with that setup.
Cheers Matt
Rear shocks on mine. I presume the same as first350's as our chassis's were about 2 weeks apart. When the shock is fully extended by winding
out the preload (no actual preload on the spring - just the slack taken up) the back end was sky high. Now wound down to get the ride height correct,
but blows through half the damper travel. I can't believe this is how they are 'meant' to be considering they are supplied by MNR.
Shock
I know the brake line is in the way - it is getting shortened next week.
Lee
Originally posted by BigLee
Rear shocks on mine. I presume the same as first350's as our chassis's were about 2 weeks apart. When the shock is fully extended by winding out the preload (no actual preload on the spring - just the slack taken up) the back end was sky high. Now wound down to get the ride height correct, but blows through half the damper travel. I can't believe this is how they are 'meant' to be considering they are supplied by MNR.
Swapping the front and rear were my 1st thoughts but doesnt work. The rears are 2 inches longer and simply won't fit with the front rockers. I
have extended the push rods by about an inch so far. Now the engine and fluids are in, it is almost there. Maybe another quarter inch.
I'll probably end up buying new shocks for the rear. Something that is correct for the job rather than driving on the bump stops!
Lee
Springs should not be loose on full droop for any situation and shouldn't be any need for helper springs with pushrod setup.
Adjust pushrods to achieve correct height.
One of the advantages of the pushrod setup is that you don't have to preload the spring to get the correct ride height unlike lesser
manufactures.
Wind the single collar up until the spring is not loose and then adjust the pushrod.
Don't tell MNR but I've put softer springs front and rear for a more compliant ride on the road. Not all road surfaces are like race tracks.
Much more compliant with 'normal' road conditions.
Lucy
Shocks too long or springs too short, they should not drop away from the collar on full droop and twang when weight is reapplied, not a problem when jacked up, just surprising when reseating, however not good when on full droop when driving i.e. hump back bridge, and possibly dangerous!
Lucy what springs did you opt for and if you dont mind me asking how much and where from, thank.
Adam
Lucy - thanks for the info. The front shocks on the push rods are fine. All adjusted and sitting firm. The problem lies with the rears. I wonder whether it is a recent thing or whether all MNR's have a dodgy rear setup.
My Rears are set so Spring wound up around 15mm after spring contacts collar under droop to get desired ride height. it leaves me with 2-3inches of
travel in rear suspension, doesnt hit bump stops, and never ride your bump stops even once or twice, it will cause damage!
My fronts can fit the larger shockers in, all apeared fine but after settling that left very little suspension travel (so dont do it!)
Ive got the shorter ones in now with heavier 250lb springs and im still concerned that under droop the rockers can hit chassis rails.
[Edited on 30/5/11 by Krismc]
As marc n said; 1/3 travel in bump
2/3 travel in droop
Krismc - rockers hitting the chassis under droop! That can't be right. That isn't right. Would it help if the bolt on the top of the
shocker was turned round? My bolt on the offside has been cut short to miss the tube.
stevegough - isn't right to have twang under any circumstances I would have thought.
bassett - for my bec setup I changed from 250lb x 8in and 150lb x 7in to 175lb x 9in and 125lb x 7in. £20 each approx
first350 - winding out the pushrods is the way to adjust for height. For my protech shocks the springs should be 5ins shorter than fully open length
of the shock. ie 14in shock = 9in spring and 12in shock = 7in spring
Big Lee - as stated at the top, at the correct ride height the shocker pushrod should be 1/3 closed with 2/3 to go when hitting a bump ( without any
spring slack at any point in the suspension travel). Sounds like shorter shocks would help. Are your springs loose at full droop when ride height is
correct?
marc n - I'm struggling to see how the situation will be better when the suspension has settled. The shock length won't change and the
spring may shorten making things worse not better (if there is slack in the spring at the moment, that will get worse, or am I missing something?)
ps I visited Protech for some work to be done on my shock. They wouldn't charge me!
I also bought my springs from them and they explained about the correct length spring for the particular shocks I had. Brilliant service.
pps I love my vortx.
^^^ have you bought my old car?
Nope it'd the bolt head that hits chassis ,so unavoidable, I've mention a few times but I keep getting told its my setup, but either way it catches. Unless I preload the spring a lot more so that its more difficult, but still happens when I lift car up!!
Can MNR give you a clue as to what is wrong with your setup?
Which part of the rocker is hitting the chassis?
If it's hitting on full droop I presume the only thing you can adjust is the pushrod. The damper is the correct length I assume? Mine is 12in on the front for my bec. What length and poundage springs do you have?
The head of the top inner bolt is hitting the chassis under droop on the RHS, it was hitting on both sides before i had repair now its hitting on rhs only.
Im not keen on this so called adjustable suspension, that cant be adjusted, its set to what ever works and no way is it adjustable.
Does your front suspension look like the second photo at the start of the thread? Are we talking about the driver's side?
I would jack up the car and measure the overall length of the shocker from centre to centre of bolts either end. I also presume it's the bolt at the top of the shocker we are talking about hitting the chassis.
You're right that at full droop the rocker arm position will be determined by the open length of the shocker. Adjusting the preload won't effect it. Adjusting the pushrod will alter the height of the chassis from the floor but not the rocker position when at full droop.
Do you have a photo?
are your rockers on the right way round kris?
Yip, Every thing is how it should be and all the correct bits and the right way round, MNR reassembled the front end the other week - ive just got it
back so going to reassemble the car and noticed it catches- so was concerned!
here are the pics..............
LHS.....
RHS.........
looks like the pushrods need winding out a bit and suspension adjusting to suit. windind the rods out should give you a bit more clearence! unless the pushrods are actually too short. its hard to tell from the pics.
Big Lee, what is the ride height of yours at the rear? i thought i'd set mine up right untill i had it corner weighted by matt at procomp, the
rear springs arn't even loose when i jack the rear end up now.
i've also gone to 175lb rear and 125lb front for a bit more complience on the road, its a little bit understeery on roundAbouts, but my fillings
are staying in
[Edited on 5/6/11 by Johneturbo]
125lb on front, wow!! my CEC has 250 cant believe you running half!
Yea, but the spring will always try to push the, damper to full extension and therefore the rocker arm against the chassis in full droop, no matter what the setting.
How much thread/tension do you have on you front springs with the push rods level?
My bloody manual doesnt have the section on setting up the front suspension, well it doesnt have anything for my car really, it might as well be for a differant make..... differant brackets, differant hubs, differant rear end, outboard, bike engined. hmm
2/3 travel in droop
marc n - I'm struggling to see how the situation will be better when the suspension has settled. The shock length won't change and the spring may shorten making things worse not better (if there is slack in the spring at the moment, that will get worse, or am I missing something?)
Hi
If you are running the STD supplied protechs from MNR fitted to the inboard front end you will suffer all sorts of problems with picking a spring
poundage to suit. This is due to the STD supplied protech being way way over valved for the application of inboard use due to the more direct acting
nature of the ratio. You can change 50Lb on poundage and not see any real difference to the handling due to the damper being the over riding
factor.
Hence we have developed a front end damper and spring package on one of the MNR'S that is running very successful now it's sorted in one the
northern spring championships. This has now been fitted to a few road cars also and works very well.
Cheers Matt
do you have any more info on this matt? and would you be interested in doing a full suspension and geo setting on my mnr once iva'd later this year? thanks
So you guys have better valving that taking into account the motion ratios of a pushrod setup.... I'm sitting here a little confused as to how
mnr could accidentally valve the shocks for an outboard setup when one of the primary factors when doing valving is the motion ratio itself....
Have anything figured out for the rear? What's your take on that problem?
2/3 travel in droop
I think what marc means is about Big lee's ride height, he's saying its to high so has had to lower the platforms, but over time the springs will sag a little to allow him to raise the platforms
