Rotting about on YouTube I found this, which for some reason just made me chuckle...
http://www.youtube.com/watch?v=xvReVRsk9EM&feature=related
why why why would you do it! hahaha
if thats got 450bhp ill show my arse in m&s's window!
This one is funnier.
FWD vs RWD.
I'm familiar with the builder from the TDI forums.
He is running a 1.9L ALH with a Cummins inline pump, and an 82mm turbo. Somewhere around 70psi of boost.
He works in a shop that builds supped up American diesel pickups... 1,ooo hp pull trucks.
His biggest trick is a custom made cast iron head and a block girdle that sandwiches the block between the head and re-enforced oil pan using external
bolts.(stock ALH engines will lift the heads and blow the gaskets at 30 psi or so)
Biggest weak point....transmissions
His biggest trick is a custom made cast iron head and a block girdle that sandwiches the block between the head and re-enforced oil pan using external bolts.(stock ALH engines will lift the heads and blow the gaskets at 30 psi or so)
Biggest weak point....transmissions![]()
Not sure the exhaust should be pointing out the bonnet though (if that's what it is?), it makes it look like a diesel train!
Yes that is funnier :-)
quote]Originally posted by morcus
FWD vs RWD.
Dont know why but this spung to mind after watchting that first one
[Edited on 2-8-12 by loggyboy]
thats crazy lol
That last one was brilliant. Too bad he couldn't get it to drive somewhat straight. More people have to build these sorts of things.
