We are off to the Nurburgring for a few days in July - just wondering what security people might recommend?
I go for a covered chain & padlock like the motor bikers use, through the wheel and wishbone.
If you use a cover let the chain dangle out from underneath as a visible deterrent.
Paul G
[Edited on 2/7/16 by 907]
I go for a covered chain & padlock like the motor bikers use as said above through the wishbone and wheel but I chain it to something like another car or a post, that way they cant drag it away. I brought the best I could find not a cheap ebay item as have seen some of these tested, think my was Thatcham approved to
Pick a hotel which has garages for rent is what we always did.
will have a look at the chains. anyone know if it will fit through a TD1.2?
I have not heard of cars going missing at the circuit. You would be lucky to get a flat bed into the carpark and steal a car in any decent time. Maybe
the gravel one at the end but I used to always find space in the main one as I was in out with people so often.
There is also far more expensive and exposed cars there. Millions of pounds of cars just parked at the sides of the roads and satellite car parks.
If you do park in the gravel car park, parking close to some one and tying a cars together is a good idea, make sure you have locking wheel nuts
though!!
I have always stayed at the same hotel that is about 30 mins away, it has a secluded car park, garages to use and CCTV.
It's not at the facility I'm worried about, it's when I'm asleep in the hotel. I guess motorbikes have the same problem and i know a Westfield isn't the most desirable of cars, it's just, in my view, easier than most to take!
I chain the rear wheels and out the car on full lock if you have a ignition steering lock.
Also as you say remove the wheel
I would also put a red led on dash
