Fuel Pressure regulator advice
scott-78 - 27/8/12 at 03:29 PM
I have a Sierra 2.0 which used to be injection but now has 45 DCOE carbs. If I leave the factory electric fuel pump in place and put a pressure regulator under the bonnet, will I need one that has a return on or should I blank off the cars return pipe to the tank?
Wondered if it'll blow a pipe if the return isnt there, or perhaps the easy option is to just include the return in the plumbing?
Any advice would be much appreciated.....
[Edited on 27/8/12 by scott-78]
richmars - 27/8/12 at 03:35 PM
I would just get a new pump suitable for the carbs.
se7ensport - 27/8/12 at 03:42 PM
You'll struggle to get a regulator that will cope with 40+psi going into it and putting out the 2-3psi that carbs need. I'd replace with a carb suitable pump, it's not worth the risk having fuel pressurised significantly above required usage.
scott-78 - 27/8/12 at 03:44 PM
didnt realise carb electric fuel pumps existed but do now, just had a go on ebay.
Thanks guys, I think Ive found my solution!
scott-78 - 27/8/12 at 03:53 PM
what fuel pressure does a 2.0 on 45's need by the way? any reccomendations?
Chippy - 27/8/12 at 09:48 PM
Long time since I played with carbs, (the devils invention), but would say around 3 psi would do the trick. HTH Ray
