RazMan
posted on 25/11/07 at 04:42 PM |
Any plumbers out there?
I've got a tiny 450mm x 400mm radiator which has rusted badly and by the looks of it could blow at any moment
When I find a replacement is there a way I can fit it without draining the system down? I've heard about using pipe freezing sprays - do these
work or am I going to need my wet suit?
Raz
posted on 25/11/07 at 05:00 PM |
You can turn both valves off and just undo the couplings, you'll only lose the water in the radiator. It will be a bit messy, just put lots of
rags down. Fit your new radiator and open the bleed valve to fill it with water.
[Edited on 25/11/07 by Peteff]
omega 24 v6
posted on 25/11/07 at 05:03 PM |
Don't you have any valves on said radiator??
DOH must update more often
[Edited on 25/11/07 by omega 24 v6]
RazMan
posted on 25/11/07 at 05:05 PM |
Silly me I am not thinking straight today. Thanks chaps
Raz
