<<  1    2    3  >>
Author: Subject: my 1st blacktop zetec install help/advice coventry
garyb12133@googlemail.com
posted on 17/10/13 at 12:24 PM Reply With Quote
Ok thanks
I am currently having some problems with my build the bellhousing is failing on the bulk head and the gear stick is I think in the wrong position here's some picture so you can see what is
http://s857.photobucket.com/user/garyb12/slideshow/
Hammy360
posted on 12/10/16 at 07:02 PM Reply With Quote
Originally posted by whitestu
also does anyone know who makes zetec inlet/intake manifold flanges???? i want to make my own bike carb manifold!
If you can get the carbs re-spaced just use the mainfold from a bike. I have Kawasaki ZX6r carbs respaced on the original bike rubber manifolds bolted to a 5mm ali plate cut to fit the Zetec.
[img][/img]
They work a treat and cost bugger all to make.
Stu
Ive built a water rail a bit like yours but havent routed it yet, is there anything saying it must run as high as possible or is it ok for the water pipes to come from the stat then go down a bit and then back up to the rad entry? just wondering if there are any issues to do with water pressure and air locks.
Cheers mate
Hammy
<<  1    2    3  >>
