mistergrumpy
posted on 12/11/08 at 08:41 PM |
Rant
Bah! Been working all weekend in the pissing rain and cold on a sodding pushbike racking my brains as to why my speedo won't work on the car.
Once this is done I can fasten down the bodywork and look at applying for SVA.
Today is my first day off so I was up at 9 and have literally been searching t'internet, trying and racking my brains all sodding day as to
what's causing it with a lot of help from 02GF74 I might add which I'm hugely grateful for.
My extra speedo sensor has already met the business end of a hammer so I can get a look inside in search of some answer but I got no where.
I just sat down an hour and half ago to try and forget it and have a play on Forza2 on the Xbox and oh! That's f'ing broke too
3 flashing red rings that mean it has to go back to Microsoft so I've had to p1ss around registering the thing so I can have it sent away.
What a load of sh1t. I've had enough of today
omega0684
posted on 13/11/08 at 12:34 AM |
i take it that you didn't get your other speedo sensor working either then? what seems to be the problem, no signal, where to mount,
calculations? what sensor and clock are you using, are they compatible, the same make?
give us more info so we can help you!
Mr Whippy
posted on 13/11/08 at 07:25 AM |
quote: Been working all weekend in the pissing rain and cold on a sodding pushbike
you don't get a car then? cut backs??
mistergrumpy
posted on 13/11/08 at 09:57 AM |
Nope no car for me. We absolutely genuinely do not have enough. To be fair though I did get to lead the remembrance day march which I thought was
really good.
Nope, no luck with the speedo yet. I'm dreaming about bleeding speedos! It appears to be the sensor. I'm using the one that came from the
ZX9 bike. I've tested as per the book and waving a screwdriver past did create a voltage fluctuation but put it onto the loom and nothing. I
bought another from a scrappy last week, I'm going to take it back in a bit and see if he will swap it just in case there's owt else.
I'm wondering if there's some kind of amplification problem because when I tested it it uses a 12V source but in reality on the loom it is
only supplied with 5V so perhaps the loss is so great at the sensor that there's not enough of a fluctuation to trigger the speedo healer. Or
summat like that.
Just to add huge thanks so far to 02GF74 and all and any further advice happily accepted.
[Edited on 13/11/08 by mistergrumpy]
posted on 13/11/08 at 12:59 PM |
only supplied with 5V.
Whoah, are you saying that the loom supplies 5 V and you plugged it in to 12 V?
mistergrumpy
posted on 13/11/08 at 01:13 PM |
Only on one of the sensors (the now battered one!) That's what the Haynes manual said to do though. 12V into the feed and 12V with a 10K Ohm
into the fedback (pink wire) then check for a fluctuation which it did and the fluctuation was very small.
I kept a sort of control and test sensor.
I've gone and got another one today anyhow which they took off an engine for me and it still don't work
focijohn
posted on 13/11/08 at 05:11 PM |
quote: That's f'ing broke too 3 flashing red rings that mean it has to go back to Microsoft so I've had to p1ss
I turn mine off and on again, when it does that. Assumed it was over heating when that happened, and it has only done it once since it has been moved!
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
