Author: Subject: Morons with high-beams...
posted on 10/2/09 at 10:26 PM Reply With Quote
What is it with some clowns?
Coming home from the station this evening... pillock 100 metres behind me in a country lane with his high-beam on...
Coming back from the pub tonight... another pillock 100 metres behind me in the same country lane, also with his high-beam on... and one coming towards me, also with his high-beam on! He eventually dipped after being flashed about 20 times... and the one following STILL didn't dip!
Arghhhh!!!!!
(Five exclamation marks - a sure sign of madness...)
<end rant>
posted on 11/2/09 at 01:21 PM Reply With Quote
What have I started...
Mr Whippy
posted on 11/2/09 at 03:40 PM Reply With Quote
my landys had two driving lights for reversing I could switch on from the dash.
Folk never did that for very long
I also fit high power front driving lights to all my cars too
cd.thomson
posted on 11/2/09 at 03:53 PM Reply With Quote
flash them with this:
http://www.fas.org/nuke/control/ccw/info.htm
Craig
focijohn
posted on 11/2/09 at 09:13 PM Reply With Quote
Get yourself a passenger and get a 5million candle power torch. It will either burn out their retinas or they will dip. My dad had one and it was good and would illuminate from a good 500m
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
MkII
posted on 11/2/09 at 10:47 PM Reply With Quote
slow down to about walking pace so they overtake you then follow them for several miles with your lights on full beam.a bit childish but at the same time quite satisfying .m.
posted on 12/2/09 at 09:11 AM Reply With Quote
Occasionally I wonder about having a strip of red corner reflectors* in my rear window - if someone doesn't dip, they get their own lights straight back. Failing that, a flat mirror that can be raised on a string...
* corner reflectors - like a cube cut on the diagonal, which return a beam of light in exactly the same direction as it came from.
Mr Whippy
posted on 12/2/09 at 10:05 AM Reply With Quote
no you mean one of these...
iank
posted on 12/2/09 at 10:27 AM Reply With Quote
The proper name is retroreflectors (used them years ago when doing some robotics work).
http://en.wikipedia.org/wiki/Retroreflector
An interesting idea - just need 3 flat mirrors to make one, but wouldn't they just return the light to their headlamps and not their eyes?
Anonymous
posted on 12/2/09 at 12:36 PM Reply With Quote
I suppose you could set them at slightly more than 90 degrees to get a bit of 'scatter'.
martyn_16v
posted on 12/2/09 at 01:12 PM Reply With Quote
I used to have a big LED sign board that i'd salvaged from a skip. It ran off a 12v power supply, so I was going to put it in the back window of my car, only it was wider than my Fiesta
In hindsight, I probably would have got myself a kicking by flashing up 'learn to drive you ****' to the wrong person
