cd.thomson
posted on 13/7/09 at 08:14 AM |
I know there was some talk of BEKs..
clicky
[Edited on 13/7/09 by cd.thomson]
Craig
Mr Whippy
posted on 13/7/09 at 09:05 AM |
hmm looks very flimsy
pewe
posted on 13/7/09 at 04:02 PM |
Touch up the welds?
He means where the load of old angle iron he's used isn't bolted together then?
Disc front brakes - that'll be to stop the front end when the back takes off on its own?
Don't get me wrong - I'm all for innovative engineering but there are limits...
Cheers, Pewe
Ivan
posted on 13/7/09 at 04:08 PM |
In the old parlance - "If it looks OK it probably is." That one just looks terribly wrong so !!!!
dinosaurjuice
posted on 13/7/09 at 05:07 PM |
the fuel tank is erm.... optimistic
iank
posted on 13/7/09 at 06:17 PM |
Oh dear, maybe someone should give him a book that tells him about using triangles in a chassis.
The brake disc will at least stop the chassis hitting the road when a tyre goes.
Anonymous
posted on 13/7/09 at 07:28 PM |
The roll bar looks just like an engine!
[Edited on 13/7/09 by MikeRJ]
RichieW
posted on 13/7/09 at 09:11 PM |
He has obviously chosen the radiator position for max airflow
Have you seen the kink in the radiator hose?
I've seen stronger tent frames than that chassis
eccsmk
posted on 13/7/09 at 10:04 PM |
that is scary
image what could happen in the wrong hands
Ninehigh
posted on 13/7/09 at 10:59 PM |
quote: Originally posted by eccsmk
that is scary
They build that?
If that holds together under foot to the floor conditions it'll definately leave a brown trail!
cloudy
posted on 13/7/09 at 11:34 PM |
I can see what's happened - he's finally realised that you can't drive the chain downwards on a gsxr due to a combination of
castings, clutch mount plate and gear selector shaft - Almost came a cropper in R4 and that's driving chain rearwards!
www.warnercars.com
RickRick
posted on 15/7/09 at 08:10 AM |
nice choice of radiator position, and kinking of water pipe
my brother has a gokart, powered by a pair of wagon turbo's wokring as jet engines, it's good for about 40 at the moment, but drinks
kerosine like it's going out of fashion
[Edited on 15/7/09 by RickRick]
