cd.thomson
posted on 15/7/09 at 02:42 PM |
respoking a bike
Hi cyclists, I've just bought myself a second hand peugeot road bike for probably more than its worth but for a fraction of the cost of a new
bike.
Everything "mechanical" on it works fine, but the rear wheel has 3 broken spokes. What kind of cost am I looking at to get the rear wheel
respoked at a bike shop?
Craig
Staple balls
posted on 15/7/09 at 03:11 PM |
If it just needs a couple of spokes and truing, you're probably looking at 35p/ea for spokes (give or take, depending if they're butted,
or made of silly materials and stuff) and I'd guess* about a tenner for the work.
Take the wheel in with as much as you can remove removed (Tyre, tube at least, cassette if you can)
That'll make them like you more than if you roll up with a whole grubby bike and save you a few quid.
*Last worked in a bike shop many, many years ago, and forgot many things since then.
Course, you could do it yourself for about a tenner in tools (spoke key, cassette tool and home made chain whip) along with a ruler to measure the
original spokes (remember left and right sides are usually a few mm different)
posted on 15/7/09 at 09:10 PM |
locoster way it to DIY.
spokes on the drive side (cassette) can only be removed if the cassette is take off - this is either a screw on affair (olf type) or a splined jobby
held on by a lock ring.
for the latter you need special tool to uindo it and a chain whip - again can DIYU from old chain and strip of metal sheet.
the spokes on other side can usually be removed without takingt off teh cassett but not always if the cassette has bing cogs.
look at how equivalent spoke is laced and feed it through same way so it crosses same number of times and in similar place.
then just tension the spoke.
posted on 16/7/09 at 09:10 AM |
I took my rear wheel in last year and the bloke behind the counter said leave it with us it's about 3 weeks wait at the moment I bought the
removal tool for £4 and did it at home. Put the tool in the vice, drop the wheel on it and spin it and it came off easily.
Ninehigh
posted on 17/7/09 at 08:33 PM |
Are the spokes all together? If they're widely spaced apart (the broken ones that is) is there any danger in leaving them broken?
Steve G
posted on 17/7/09 at 09:23 PM |
Best option is definately to get them replaced by someone who knows what they are doing. If they arent correctly tensioned then spokes will just keep
breaking depending on where they are most stressed. Doing it properly means all 32 / 36 spokes should carry equal load and mean the wheel is stronger
/ stay true for longer. I've had one done while i waited for 30 mins
RK
posted on 18/7/09 at 02:04 AM |
Again, take it in, it's an easy peasy job for someone who knows that sort of thing. Bring it by here in Quebec, and I'll do it for free.
Of course, you'd have to help me finish my car for payment, so it wouldn't be free.
dinosaurjuice
posted on 18/7/09 at 07:09 AM |
ive worked in a bikeshop for many years and have built probably hundreds of wheels.
dont try it yourself. if you want to learn start on a wheel you dont use. preferably with a cheap and flexible rim (gets you in good tensioning
habits)
Where i worked we charged about £15 labour for rebuilding a wheel.
wil
clanger
posted on 18/7/09 at 07:53 AM |
There you go.
Used this to build motorbike wheels and MTB stuff.
Be methodical and its easy peasey
Spoked Wheel buildling
