Ninehigh
posted on 20/11/10 at 09:58 PM |
How it's done
Start with 5 monkeys locked in a cage.
Hang a banana from the roof on a string and place a set of stairs under it.
Before long the monkeys will go to the stairs and start to climb toward the banana.
As soon as the first monkey touches the stairs, hose the other monkeys with cold water.
After a while another monkey makes an attempt with the same result. All the other are sprayed with cold water.
Pretty soon, when another monkey tries to climb the stairs, the other monkeys will try to prevent it.
Now, put away the cold water. Remove one monkey from the cage and replace it with a new one. The new monkey sees the banana and goes to climb the
stairs. To his surprise and horror, all of the other monkeys attack him. After another attempt and attack, he knows that if he tries to climb the
stairs, he will be assaulted.
Next, remove another of the original five monkeys and replace it with a new one. The newcomer goes to the stairs and is attacked. The previous
newcomer takes part in the punishment with enthusiasm!
Likewise, replace a third original monkey with a new one, then a fourth, then the fifth. Every time the newest monkey takes to the stairs, he is
attacked.
Most of the monkeys that are beating him have no idea why they were not permitted to climb the stairs or why they are participating in the beating of
the newest monkey.
After replacing all the original monkeys, none of the remaining monkeys have ever been sprayed with cold water.
Nevertheless, no monkey ever again approaches the stairs to try for the banana.
Why not?
Because as far as they know that's the way it's always been done around here. And that, my friends, is how company policy begins.
Angel Acevedo
posted on 22/11/10 at 05:49 PM |
That´s a Paradigm...
posted on 25/11/10 at 12:07 PM |
No, it's a plantain.
Angel Acevedo
posted on 25/11/10 at 12:33 PM |
I was not familiar with the word until I looked on Wiki, (english is not my mother tongue) until then i thought you were serious...
It´s a good one...
[Edited on 11/25/2010 by Angel Acevedo]
posted on 25/11/10 at 12:48 PM |
Yes but unless you work for a company that employs monkeys to fetch bananas from upstairs it shouldn't really affect you should it?
Ninehigh
posted on 25/11/10 at 07:29 PM |
Most companies employ monkeys, that's why the government had to define "peanuts" (although they did call it minimum wage...)
Mark Allanson
posted on 25/11/10 at 07:53 PM |
That is SO true, I am unfortunately the latest monkey!
