franky
posted on 13/3/11 at 10:00 PM |
Would it matter having one rim 0.5" wider on the rear?
Strange one.... I've got some new end of the line wheels. However one is 8J instead of 7.5J like the rest.
Would it matter on the rear of the car? Tyres would be the same size.....
MakeEverything
posted on 13/3/11 at 10:06 PM |
I would say so, yes. When cornering, i think youll find its easier to corner one way than the other.
Kindest Regards,
Richard.
woolly
posted on 13/3/11 at 10:11 PM |
if noticed should fail mot, think i may also feel different at speed round corners due to the side wall defection.
ReMan
posted on 13/3/11 at 10:16 PM |
Doubt you'd know the difference or if it would be noticed
Edited for speeling under the influence!
[Edited on 13/3/11 by ReMan]
www.plusnine.co.uk
posted on 13/3/11 at 10:25 PM |
Apart from foobarring the handling it would be an MOT failure
Mark G
posted on 13/3/11 at 10:38 PM |
I have to disagree with the posts above.
half an inch is not a lot when it comes to wheel width. You can use the same tyres on different size wheels.
example 7.5j and 8j you could probably get away with using a 225 tyre. As MOT standard you may be ok as I don't think wheel size comes into it.
Tyre size however does have to be the same on the same axle.
As Woolly said if you use the same tyres on different size wheels you will notice slightly different side wall deflection characteristics.
franky
posted on 14/3/11 at 06:53 AM |
I've got 225 tyres to fit but I did think that the side wall deflection characteristics would have an impact Looks like i'll have to
send them back.
Ben_Copeland
posted on 14/3/11 at 07:17 AM |
Personally wouldnt even consider it. You rely heavily on the fact these cars go round corners well, why take the risk !!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
coyoteboy
posted on 14/3/11 at 11:24 AM |
Probably not an MOT fail due to tyre size remaining the same. However it will affect the offset of the rim edges, so altering the effective track
width on one side. Seems a bit of a risk to take IMO - I can tell when I'm 2psi down on on tyre, not sure I fancy a whole different rim.
balidey
posted on 14/3/11 at 11:30 AM |
as its end of line then I presume there was a production run, so there should be some out there.
So I would look out for another in either 8 or 7.5 and then sell one of yours on.
Dutch bears have terrible skin due to their clogged paws
franky
posted on 14/3/11 at 11:32 AM |
closer inspection with un-tired eyes have shown another issue..... its an inch bigger
Liam
posted on 14/3/11 at 06:57 PM |
If the rims are the same offset then the difference in width wouldn't affect track width. I still wouldn't though.
iank
posted on 14/3/11 at 07:28 PM |
In diameter? I'd get the vendor a guide dog.
Anonymous
chris-g
posted on 14/3/11 at 10:07 PM |
You could always go oval racing or track days at Rockingham.
franky
posted on 14/3/11 at 11:17 PM |
Yep its a bugger. should it could help with the turning circle(going one way!).
So now i've got the rubber but nothing to put it on!
dlatch
posted on 18/3/11 at 12:55 AM |
most chaps would be happy with an extra inch
no chance of finding another wheel to replace the ones thats too wide?
posted on 18/3/11 at 07:53 AM |
The biggest reason for not using mismatched wheels is is the offset --- the back space is likely to be the same so the wider wheel will have its
centre line 1/2" futher outboard ----- that will make the car crab under braking and to a lesser extent acceleration.
