Author: Subject: one wing landing? Is it possible ?
AndyW
posted on 15/4/11 at 03:40 PM Reply With Quote
Yup
link
steve m
posted on 15/4/11 at 05:01 PM Reply With Quote
I am sure that has been on here before,
It has been on one the other forums i frequent and was declared a fake
geoff shep
posted on 15/4/11 at 05:20 PM Reply With Quote
That one was real I think, but happened some time ago - there was one of a prop aerobatic aircraft that was faked.
http://www.f-16.net/varia_article8.html
russbost
posted on 15/4/11 at 05:49 PM Reply With Quote
Yes, that one was genuine, the faked one was a Red Bull prop plane, very cleverly done, but it was a radio controlled plane that lost the wing, cleverley cut with footage from a real airshow.
It is only possible with a massive amount of power to weight on tap, hence possible with the F15 or radio control plane, but not with an ordinary propellor driven aircraft. Even in the cases where it's been done it still requires tremendous skill on the part of the pilot & a landing speed of more than double what is normal. The other minor detail for most prop aircraft is that the wheels are frequently attached to the wings - could make landing a touch trickier with one wing & one wheel!
[Edited on 15/4/11 by russbost]
posted on 15/4/11 at 06:01 PM Reply With Quote
cant see why he bothered myself, the risk to the pilot surely outweighed the scrap value of that lot, so why not just eject?
scudderfish
posted on 15/4/11 at 06:08 PM Reply With Quote
F15 is also helped by the fact that it gets a lot of lift from the aerodynamics of it's fuselage.
posted on 15/4/11 at 06:17 PM Reply With Quote
Perhaps because ejecting is in itself a high-risk action - most pilots end up a half-inch or so shorter, permanently, due to spinal compression.
mackei23b
posted on 15/4/11 at 06:28 PM Reply With Quote
1st ejection in a Martin Baker seat and you join the club and get a nice tie!
After iether the 2 or 3 you can't fly again!
[Edited on 15/4/11 by mackei23b]
deltron63
posted on 15/4/11 at 06:34 PM Reply With Quote
They can land with NO wings.............. it's called a crash
posted on 15/4/11 at 06:45 PM Reply With Quote
ISTR there was a case of a US Navy fighter that took off and landed with the wings folded ----- not sure if it was an LTV F8 or an A7
posted on 15/4/11 at 07:33 PM Reply With Quote
There's a surprise. No doubt an opinion expressed by an expert 13 year old.
Benzine
posted on 15/4/11 at 07:45 PM Reply With Quote
should have ditched it and just dipped into the $3 billion of US funding for a new shiny one
907
posted on 16/4/11 at 06:34 AM Reply With Quote
I almost believed this up until just after the impact.
The cockpit camera, mounted in the front of the bubble, shows the pilots head spinning
as the plane rolls rapidly.
The camera would be rolling with the aircraft, as would the pilot.
The only thing that should appear to move is the scenery outside the aircraft.
Schoolboy error.
Paul G
scudderfish
posted on 16/4/11 at 07:04 AM Reply With Quote
The video is pure re-enactment for a TV show. The story is true though.
Liam
posted on 16/4/11 at 11:01 AM Reply With Quote
Schoolboy error.
Paul G
You ever use to watch 999? Those weren't the real emercencies all captured on camera, you know :p
907
posted on 16/4/11 at 09:55 PM Reply With Quote
Schoolboy error.
Paul G
But, but, but..... If it's on film, telly, or in the newspapers, it must be true.
Paul G
Ninehigh
posted on 20/4/11 at 08:56 AM Reply With Quote
This was done on a program similar to Mythbusters, and it's possible but really difficult and you only get one go.
Also iirc flying that way (with both wings) is a stunt called "Blade-ing" or something to that effect
T66
posted on 25/4/11 at 11:02 PM Reply With Quote
The video is a patched together job to add drama. Without sounding spotter like, the A4 the pilot talks about colliding with, when cut with video was a F100.
The speed of the air on the fuselage and the huge twin tail, will have increased dramatically after he gave it the gun. So less lift from one wing, but forward speed and the big tail fins allowed him to recover from the spin.
Helicopters when they lose a tail rotor when transiting dont spin out of control, because of the air passing along their fuselage, ie the rudder effect of the tailfin keeps it straight.
different matter when in the hover.
This article, looks genuine to me, with plenty of added drama.
