Author: Subject: 1.6 zetec mini supercharger...
adz h
posted on 3/5/11 at 06:57 PM Reply With Quote
Hi
I have a velocity running a 1.6 zetec on 40 DCOE's and it's all good BUT...
I also have a supercharger from a mini, so has anyone used a mini supercharger on a zetec?? I was thinking bike throttle bodies, ECU, intercooler and dump valve etc.
Any ideas
Thanks Adam
big_wasa
posted on 3/5/11 at 07:14 PM Reply With Quote
Ive only heard of one in a 7 and that was Lhd. But what a sound http://youtu.be/Ghjc_I1wQ-g
I just dont see how you can route the steering linkage on a Rhd car.
Stuart_B
posted on 3/5/11 at 07:21 PM Reply With Quote
i agree the sound
packaging will always be a problem in a seven, but with the eaton you can mount it the other side, and pipe around the inlet.
stu
adz h
posted on 3/5/11 at 07:28 PM Reply With Quote
Now that's what I am talkin about!!
I think I could get it in over the exhaust, I think I will mount it and see how it looks
BigLee
posted on 3/5/11 at 07:51 PM Reply With Quote
I recall someone doing a supercharged crossflow in PPC magazine 6 months back. That was in an older westfield. Check the back issues.
Lee
adz h
posted on 3/5/11 at 07:57 PM Reply With Quote
I have seen post on here someone using a m45 charger on a zetec,
I am just looking in to throttle bodies, bypass valves, dump valves, ECUs, pulley sizes, injectors ect.
Any help would be good
MakeEverything
posted on 3/5/11 at 08:02 PM Reply With Quote
Im using one on a renault 21 engine.
Kindest Regards,
Richard.
adz h
posted on 3/5/11 at 08:23 PM Reply With Quote
How have you piped it up.
Have you used a dump valve?
What's to stop me using the DCOE carbs I already have and just rejetting.?
MakeEverything
posted on 3/5/11 at 08:46 PM Reply With Quote
Check out my blog at the bottom of each of my posts. theres videos there as well.
Theres nothing stopping you using the DCOE's, but ive never done that and would personally go EFI.
Kindest Regards,
Richard.
jollygreengiant
posted on 3/5/11 at 10:43 PM Reply With Quote
Personally, with a super-charger, I would put the Exhaust straight out over the top of the side rail and with a heat shield arranged like I did in my normally aspirated car, then mount the super-charger under the exhaust.
I would think one of the best guru's on this sort of fit (ok he did a Duratec, rather than a Zetec, but the principles would be the same) would be Flak Monkey. Have a look at his build thread in the engines section (IIRC).
Also of interest to talk to would be Madteg (based in kettering), He built a VERY quick 2.0 Zetec Turbo and knows what their strengths and weekness's are.
