jacko
posted on 19/8/12 at 04:38 PM |
Question about removing alloy rivets
Hi All some one i know asked me what is the best way to remove solid alloy rivets out of lead they can't be drilled ?
This is on a Aircraft he is renovating
Jacko
Chippy
posted on 19/8/12 at 04:57 PM |
I asume that these are the hammered in place type of rivet. I did some work on a very old race car that had alloy skin that didnt want to be damaged.
The only way we came up with was to dremel off the head, (carefuly), and then tap the pin part through it worked but was very time consuming and as
there were several dozens of rivets a real pain. HTH Ray
johnH20
posted on 19/8/12 at 07:18 PM |
I don't know the answer to this but as a lead there are several companies in the historic restoration business who must do this a lot. Bit of a
search required but I remember seeing a dismantled Surtees TS5 at the Racing car show a few years back on an exhibitors stand.
DIY Si
posted on 19/8/12 at 08:01 PM |
All the options I can think of are variations on cutting the head off and knocking the solid pin through.
Sun Tzu, The Art of War
jacko
posted on 20/8/12 at 05:26 PM |
According to the mate of mine its not as easy as that without disforming the lead
Thankyou for any advice so far
Jacko
richard thomas
posted on 20/8/12 at 06:50 PM |
Disc head off, centre drill the rivet shank at 1/2 rivet shank diameter to the depth of the material it is holding together leaving the tail
undrilled, carefully block back of structure and knock rivet shank out with a punch 0.1mm smaller than diameter of hole.....
[Edited on 20/8/12 by richard thomas]
posted on 20/8/12 at 07:19 PM |
pure lead melts at 327.5 C - quite low - is melting them an option?
spiderman
posted on 20/8/12 at 07:32 PM |
The rivets are alloy the material being held is lead and needs to be left undamaged, so I don't think that will work.
I am surprised that lead is used in the construction of an aircraft though.
Spider
paulf
posted on 20/8/12 at 08:37 PM |
Is it still attached to the aircraft? if its just a lead weight with some alloy rivets in it then maybe it could be immersed in caustic soda and the
rivets dissolved?
Paul
Toprivetguns
posted on 20/8/12 at 09:19 PM |
Im an aircraft engineer, why cant they be drilled ? As long as your delicate and start drilling with a small drill bit. Then proceed to work your way
up to the diameter of the original hole I dont see a problem.
Also if your going to try the rivets, try using cobalt drill bits.
Any pictures or description of the said parts ?
Only drive as fast as your angel can fly... !
foskid
posted on 20/8/12 at 09:24 PM |
I'm intrigued as to why they can't just be drilled out, cosmetic reasons, affecting the mass or position of the lead perhaps. Most lead
on an aircraft is fitted as ballast or as a "mass balance" to prevent flutter in manually controlled flying surfaces, usually out of sight
fitted in horns fwd of the hinge line. Any material, lead or alloy removed would have to be replaced within fairly narrow limits and they are
generally bolted in anyway. So what is so particular about this piece they can't be removed by drilling. Other than that, Richard Thomas has
Knocked on the head so to speak
![](/images//smilies/tongue.gif)
[Edited on 21/8/12 by foskid]
He knows nothing and thinks he knows everything. That points clearly to a political career.
George Bernard Shaw
jacko
posted on 21/8/12 at 06:21 PM |
Thankyou all for you input ,
I am afraid i don't have the answers to some of your questions
My daughter went for a flying lesson on Saturday and while i was there i was talking to some one who i rebuilding a plane but he had the problem with
the rivets
What i thought was cut the heads off the rivets then pour boiling water on the lead to expand it + punch out the rivets
I will ask him next time we go what and how he got on
Jacko
richard thomas
posted on 21/8/12 at 07:35 PM |
I did my apprenticeship at Saints, I think we are in the same trade given your location....?
(Just looked in your photo archive....now I now we are in the same trade...)
[Edited on 21/8/12 by richard thomas]
