Author: Subject: cracked bath
ali f27
posted on 17/1/13 at 09:03 PM Reply With Quote
cracked bath
Hi anybody know how to seal cracked plastic bath bit of an emergency will replace bath but could do with repair just for now
owelly
posted on 17/1/13 at 09:14 PM Reply With Quote
Araldite.
http://www.ppcmag.co.uk
blakep82
posted on 17/1/13 at 09:39 PM Reply With Quote
A bit of pond liner (to take care of the crack getting bigger) and some PU stuff like sikaflex or tiger seal?
________________________
austin man
posted on 17/1/13 at 09:45 PM Reply With Quote
Fiberglassover it using the tissue and resin
Grimsdale
posted on 17/1/13 at 10:18 PM Reply With Quote
a big sheet of plastic..... difficult to remove the plug though!
snakebelly
posted on 18/1/13 at 03:31 AM Reply With Quote
Biggest problem wont be sealing it but keeping it sealed, modern baths are actually quite flimsy so even if you araldite it I'm betting it will crack again, fibreglass with tissue and resin gets my vote as it can be applied way past the crack and will hopefully add enough strength to stop the crack propagating
Andy S
posted on 18/1/13 at 06:50 AM Reply With Quote
Would have thought that a wide bead of silicone sealant would be your best bet
cliftyhanger
posted on 18/1/13 at 07:30 AM Reply With Quote
if you can get behind it fibreglass there a few layers. Grind out the crack carefully (dremel or burr in a drill or whatever) after and use gelcoat filler. Wet and dry, followed by t cut and it is almost invisible....
I had to repair a bath in a rental at short notice, and to get the bath out was a serious issue. So the repair stayed for about 8 years until the bathroom had a refurb. Nobody ever mentioned it.
this is assuming a fibreglass bath.
posted on 21/1/13 at 09:30 AM Reply With Quote
ditto fibreglass. Others wont last long - silicone wouldnt have enough to seal on, and harder glues will crack.
owelly
posted on 21/1/13 at 10:21 AM Reply With Quote
My chum dropped a tile into his plastic bath and cracked it. I popped up with my f/glassing gear but getting under the bath was a pita so vleaned the crack with wire wool and nlobbed Araldite on it as a temp repair. That was two Christmasses ago and its still holding strong...
tegwin
posted on 22/1/13 at 12:41 PM Reply With Quote
1 strip of proper duct tape would do the job for a few months
www.verticalhorizonsmedia.tv
dhutch
posted on 22/1/13 at 03:50 PM Reply With Quote
If going down this route, drill a 5mm hole at the end, or just beyond the end, of the crack.
And use PVC duct tape or electrical insulation tape, rather than fabric containing gaffa tape such as 'duck tape'. Terms are confusing but gaffa tape isnt that waterproof long term.
Daniel
rallyingden
posted on 22/1/13 at 04:05 PM Reply With Quote
I dropped a tile in the bath and cracked it but as it was being replaced in a few weeks I "repaired" it with a bit of blue tack stuck in the hole, from the inside of the bath !
My few weeks turned into 3 months but it held OK
RD
perksy
posted on 22/1/13 at 05:21 PM Reply With Quote
Had to do one of these once and used fibreglass tissue and resin
Lightly sanded the underneath of the crack and then applied the resin & Tissue
Also used this method on a cracked plastic toilet cistern
