philw
posted on 31/8/14 at 10:23 AM |
Removing Ceramic tiles kitchen/bathroom
How the hell do I remove tiles that are fixed to stud walling? is it possible? so far I have managed to rip chunks out of the wall is there a proper
way of doing it or will I have to get the whole area drylined?
Must try harder
bigfoot4616
posted on 31/8/14 at 10:54 AM |
i always remove the lot if its tiled onto plasterboard, much easier. you also start with a nice new clean surface to tile onto.
just make sure you replace any plasterboard in wet areas with a waterproof tile backer board( i usually use marmox) or tank the plasterboard.
posted on 31/8/14 at 12:07 PM |
Tiles cannot be removed from unplastered plasterboard, just rip it all off and start again.
big-vee-twin
posted on 31/8/14 at 12:51 PM |
There's only one way - the hard way.
Remove the plasterboard and start again.
http://www.triangleltd.com
bigfoot4616
posted on 31/8/14 at 03:12 PM |
unless its going to be really hard to reboard i wouldn't even try and remove tiles from skimmed plasterboard
John P
posted on 31/8/14 at 04:51 PM |
I've had some success using a flexible stripping knife which I pressed so the blade was virtually parallel with the wall and carefully hit it
with a hammer. This was quite successful over most of the area although there was one small section I had to repair afterwards.
If there's old adhesive still on the wall afterwards, which there probably will be, then try a wallpaper steamer which softens it (possibly only
if it was originally the ready mixed type) and makes it fairly easy to remove without doing any further dama
Good luck,
John.
bigfoot4616
posted on 31/8/14 at 05:44 PM |
by the time you've done all that you might as well rip everything of and start again.
having said that i'm doing it for paying customers so labour costs money, if your doing it for yourself at home i suppose labour is free.
philw
posted on 31/8/14 at 06:39 PM |
Thanks for the replies guys, I've bitten the bullet and cut the offending area out with a stanley knife, I will get some plaster board tomorrow
and patch it in
Must try harder
