james h
posted on 1/9/14 at 07:12 PM |
Advice on building a PC?
After my 7 year old laptop gave up the ghost last month, I've decided to build my own PC.
I'm returning to uni for the last two years of my engineering degree so I'll need to be able to do some CAD and CFD work.
I'd like to be able to use it for at least four years when (hopefully) I'll have a job that will enable me to upgrade again.
I'm looking for some general advice on what processor (i5, i7, other?)/graphics/motherboard to go for and where to buy the components from. I
don't have a huge budget but I'd like to get a medium to high performing PC that can manipulate and render 3D items without too much
hassle. I know that some of our future projects will be quite processor intensive.
Any help will be greatly appreciated!
James
![](/images//smilies/smile.gif)
drt
posted on 1/9/14 at 07:20 PM |
http://www.ankermann.com/?language=en
If you like to FEM a lot, you need a lot of processing power.
I7 it would be,
And specially for cfd a whopper of a graphics card.
Ankermann does very good deals and you don't need to worry
if everything works good together.
If you want to build it yourself... it will cost more
And it is a hassle of finding the right combo's.
stevebubs
posted on 1/9/14 at 07:24 PM |
The days of buying PC components individually to get a cheaper PC are pretty much long gone, I'm afraid...
Check out the costs of what you want in component form, then compare with something that's ready-built...
Don't forget to add the cost of O/S....not necessarily an insignificant amount...
Irony
posted on 1/9/14 at 07:25 PM |
I would just buy one from the likes of dell outlet. Dell spend millions on perfecting there systems so all the components work together in harmony.
You just won't get that sort of reliability with a home built system. You'll spend more in the long run.
stevebubs
PS I would say the forward is an i7 with as much memory and as good a graphics card as you can afford....
HowardB
posted on 1/9/14 at 07:54 PM |
I have an i7 and 32gb of ram, it crunches through FEA slowly,.. we have a few tower system things that are recommended by the software manufacturer
and they fly,....
however at least one has an unsupported video card now,...
look at the software and get a machine as good as or as near to the spec as the software company recommends.
hth
Howard
drt
posted on 1/9/14 at 07:56 PM |
second that....
check out
james h
posted on 1/9/14 at 08:03 PM |
and they fly,....
hth
I hadn't thought of looking at it that way, it will definitely help narrow down the options for sure
whitestu
posted on 1/9/14 at 08:43 PM |
We've just put together a gaming PC for my son and it does work out a bit cheaper to buy the bits, but not by much. I had an OS licence which
saved a few quid.
We used an AMD FX 8350 8 core processor, Nvidia R7 260x graphics card, 16gb RAM, 128 gb SSD and 1tb sata.
It flies along with all the Minecraft stuff he does - I've not seen anything that hammers a PC like Minecraft with all the mods, texture packs
etc.
Unless you are keen to build for the sake of it [we were] it is probably best to buy ready built.
Stu
inkafone
posted on 1/9/14 at 08:52 PM |
There's still a few computer fairs around. The vendors are knowledgeable and you will save quite a few quid compared to a Dell plus
there's the satisfaction of self-build. Buying secondhand (try HERE is
good - change the hard drive for an SSD and use the original for backups. Building a PC is pretty straightforward plus there's plenty of advice
on the net.
bigfoot4616
posted on 1/9/14 at 09:01 PM |
its no cheaper to build your own, but it needn't cost any more.
its also more enjoyable to build it up from scratch rather than just unpacking and turning on.
bit of research to make sure you get stuff that will work together and it will be as reliable as any prebuilt one.
i've built my last 2 and done quite a few cpu/mobo upgrades over the years and have never had any problems.
i usually have a look here http://www.overclockers.co.uk/index.php find what i want, then see if i can get it cheaper elsewhere as they
aren't usually the cheapest. having said that the service is very good so unless its a decent saving i go with them.
james h
posted on 1/9/14 at 10:01 PM |
Lots of good advice here, thanks! Looking at computers is like going to an Indian or Chinese, there are so many options and combinations it gets quite
frustrating to find what I actually want!
craig1410
posted on 1/9/14 at 10:34 PM |
Sorry mate but that made me laugh...
Here's a recent review on laptop and desktop reliability which might be of interest. Assuming you don't want an Apple machine, your next
best bet is probably an Asus machine.
I do agree that the days of building your own machine are long gone and I say this as someone who built his own high-end PC's from the mid
1980's through the 8086, 80286, 386, 486, Pentium/Cyrix/AMD K6 & Athlon/Athlon XP generations. My journey came to an end on Aug 11th 2007
when I bought an iMac. That machine is still going strong today and is used daily along with a few other Apple machine in the household.
If you do buy a PC then seriously give a recent Linux operating system a try rather than defaulting to windows. You might need to use Windows for some
software you want to run but give Linux some thought.
Here is a good resource for hardware reviews: http://www.tomshardware.co.uk
and another:
http://www.pcpro.co.uk/alist
Asus here: http://www.asus.com/uk/Desktops/
Good luck,
Craig.
[Edited on 1/9/2014 by craig1410]
Irony
posted on 2/9/14 at 07:28 AM |
and another:
Good luck,
Craig.
Funny you should say that as I am currently typing this on a Mac. Everyone in my office uses macs and we have never had a single machine go down in
the entire 12 years of the office operating. I wouldn't touch a windows machine with a 10ft pole, if one of my machines goes down I am losing
business. However I wouldn't touch a home built machine with a 20ft pole. Assuming I could get a pole of such a length.
posted on 2/9/14 at 07:31 AM |
I'm just in the process of building a PC - just waiting for Amazon to ship the last few parts.
I wanted a medium power box that was small enough to sit on the corner of my desk, just to run the Windows apps that simply can't be replaced by
anything on Linux. I had a big powerful but older PC but that won't run Win8, and I have a 4-year-old laptop on my desk for which Intel
won't write Win8 video drivers (thanks Intel). I have been running Win8.1 in a virtual machine under Linux, but that hasn't been a
rewarding experience.
The Mini-ITX case will take less space on my desk than the laptop, barely 5" high, and will have just the CPU fan (low-power CPU, no graphics
card). 8GB memory, 1TB HDD, DVD R/W drive, and I already have the Win8 Pro 64-bit installation disk, a keyboard and a mouse. I'll be sharing
the monitor with my Linux box. The total cost is going to be around £240. It could have been cheaper, but I picked a fancy case...
I've not seen a bare-bones PC with that spec for anything like that sort of money.
Once the new box is up and running my laptop will be converted to a Linux box - it's just a case of swapping out the HDD as I've already
got one set up and ready. It's amazing how much quicker Linux Mint is than Win Vista on the laptop, considering that the Linux is the very
latest 64-bit version with all the usual bells and whistles.
craig1410
posted on 2/9/14 at 07:50 AM |
@Irony.
Yeah same here. I'm a software consultant/developer and almost everyone in my office uses Macs now. Even the Linux/Android fans use Macs and
dual boot to Linux. As you say they are very reliable and if they do fail then Apple support is second to none.
As for home built PCs, it depends who built them and what components they used. I used to read countless reviews before buying my parts and then
assembled them with extreme care with top quality thermal compound, copper heatsinks, fans, cables (all neatly secured) etc. It's the detail
that matters and being a bit OCD helps!
My machines would typically last reliably for 5/6 years with incremental upgrades along the way. The PSU and case is one of the most important parts
and sadly a lot of home builders skimp on that bit and spend maybe £30 and get a free set of speakers thrown in... I used to spend more like £150 on
case and PSU alone and that was in early 2000's. That's not so bad as long as you buy shortly after a motherboard format change and not
shortly before one!
Anyway, nowadays it's just not worth building PCs but mainly because hardly anyone wants desktop machines now and home built laptops never
really caught on. Personally I need a machine which "just works" and for me that's currently a Retina MacBook Pro 15" with
16GB ram, 500 GB SSD and quad core CPU. How times have changed since my Amstrad PC-1512 in 1986... 😄
[Edited on 2/9/2014 by craig1410]
Chris_Xtreme
posted on 2/9/14 at 08:01 AM |
I'm an IT bod and whilst I used to when I had time (ie before kids!) build my own pcs etc.. 3yrs ago when I decided to get one decent machine in
the house I went with these guys:
https://www.pcspecialist.co.uk/
3yrs ago the service was spot on.
I pretty much picked the combination of components I wanted and they put it together and tested it for me. One time consuming thing in the passed,
which has got far better is a situation where for eg the cpu and motherboard don't work together. ship them back and individually they work, I
lost about 2months returning parts until the seller eventually gave in and tried my 2 parts together.
whilst I am a linux bod, windows does have it's place and especially as some software just isn't written for linux. See what the package
you need says.
Building your own PC for the fun and learning experience is great, but if you just want something to a spec you want I would buy it made and tested
these days.
There are many parts of the PC that are going to be the bottleneck depending on how the software works/does. With rendering I would imaging the best
graphics card that the app supports is going to be the biggest help as it will probably offload all of the work to it, and you can then save on the
cpu. If it is I/O intensive, it wont matter how faster CPU you have as you will always be waiting for data from the HD, so SSD will help.. really
depends on what you are going to use if for and how that main application works.
mcerd1
posted on 2/9/14 at 09:16 AM |
Assuming you don't want an Apple machine, your next best bet is probably an Asus machine.
I'm still not much of an apple fan - but Asus stuff is always my first choice
most of there stuff is pretty bombproof and often has some nice extra features too - even my 2002 cheap laptop is still going
I currently have a 4 year old 1st gen i7 (i7 920) at home, a 3 year old 2nd gen i5 quad core (i5 750) at work (built it myself) and my mum's 4th
gen i5 - All running on an Asus boards / graphics with corsair memory and none have given me any trouble yet
where as the other 15 folk at my work got given newer HP's in the last year with 4th gen i7's - they aren't actually that much
quicker than my old 1st gen one and they have had a couple failures already
I've still got good memories of my old K62-500, it used to punch far above its weight next to old P3's
but I wouldn't say the days of building your own are over - especially if you can save bits /OS's from an old machine
even if you can't save any bits I built my mum's machine inc a new copy of windows for ~£400 which is about the same as a basic dell
etc.
but its got an decent i5, a good asus board that I know will last forever and decent quality ram, PSU, HDD etc... and room to expand it if need
be.
the 'off the shelf' machines for the same price had an average i3, cheap components and no room for any expansion
when I built my own one I looked at the dell xps / alienware stuff (lots of people were recommending them at the time)
it was £700 - 800 more than mine ended up costing and that was with the exact same MB, CPU, PSU and RAM - the only difference was there HDD was £100
more and it had a fancy case - what a rip off !
[Edited on 2/9/2014 by mcerd1]
dhutch
posted on 2/9/14 at 12:11 PM |
Build about 2-3 machines between 2000 and about 2005 when I went to Uni and found better things to spend time on, includes those with engines and
wheels...
Main reason for that was wanting a quiet desktop, so it was about large heatsink and fans, running them on 7v, and banging a decent amount of ram
in.
Now I have a fanless shuttle barebones and a HP elitebook bought 18months old on eBay.
Work hast replaced all its Lenovo S20's with S30's, dont know what the options for cheap used cad boxes are.
Where are you at Uni? Did 5 years of MechEng (inc placement year) at Loughborough.
Daniel
james h
posted on 2/9/14 at 10:10 PM |
All good stuff as usual! Interesting to hear about the price difference (or lack of) between speccing a PC from a vendor vs buying components
individually.
I will veer away from linux at the moment - the industry I am going into after uni doesn't use linux and I know uni doesn't for
engineering applications.
Interestingly, my Belgian friend absolutely loved linux to death, couldn't get enough of it. He's now pretty much an Apple fanboy now,
despite doing a computing PHd at Cambridge. He's a sucker for shiny stuff though.
wheels...
in.
Daniel
I'm at Brunel doing Motorsport engineering, MEng, 5 years too - just getting back from my placement year and I will be designing parts of next
year's Formula Student car. Can't wait! Another BEC project ![](/images//smilies/bigsmile.gif)
phelpsa
posted on 3/9/14 at 09:12 AM |
My Dell XPS14 was more than sufficient for formula student use (with NX7.5). Despite having an XPS 8100 with all the bells and whistles I rarely found
any difference in performance or any need for better performance!
mcerd1
posted on 3/9/14 at 11:54 AM |
It would be easier to recommend a spec for your PC if we knew which software you intended use...
specific programs may run fast on one system and slow on another with apparently similar specs - all you can really do is look at benchmark tests for
the software you need to run
also bare in mind that laptop cpu's are never as powerful / quick as the equivalent desktop and desktops are cheaper too
even my 5 year old i7 920 (2.66GHz - but I could overclock it to 4.0GHz easily if I felt like it) is only a tiny way behind the power of some of the
latest i7's being offered in the likes of dell XPS laptops for more than £1500
you don't need to run out and get the very latest version of everything, I'd go for the stuff that's been out a long enough for the
price to have dropped a little
I can recommend these guys if your looking for components: http://stak.com/common/home
I've used them for years and never had any issues with them
coyoteboy
posted on 3/9/14 at 11:57 AM |
I Agree with one of the early posts. I've built literally dozens of PCs and rebuilt them over the years. Recently found it makes no sense to do
so, financially or otherwise. You can use something like scan.co.uk to generate a custom machine and they deliver a bare bones box as per your spec.
Used it recently to get a work CAD machine - 8 core, 4.4Ghz, 16gig of ram running on a 250Gb SSD, AMD FirePro V4900. Works fine on assemblies up to
(so far) up to 300mb in solidworks and has no issues at all with CFD/FEM.
Volvorsport
posted on 3/9/14 at 04:11 PM |
interestingly , im in the market for a new computator , im off on a catia v5 course , so any recomendations are welcome
www.dbsmotorsport.co.uk
getting dirty under a bus
