Author: Subject: WTD Shock absorber brackets
nilocp
posted on 2/10/16 at 05:17 PM Reply With Quote
Shock absorber brackets, but not Rogue Engineering.
They do not respond!!
Talon Motorsport
posted on 2/10/16 at 05:41 PM Reply With Quote
How many brackets are you wanting I'm having a batch of Roadster brackets cut this week.
nilocp
posted on 2/10/16 at 06:05 PM Reply With Quote
Just a car set, (8) but I think 32mm and 1/2in hole
Talon Motorsport
posted on 2/10/16 at 06:27 PM Reply With Quote
Roadster damper brackets are 34mm id with 12.1mm holes although you could drill them out £2.50 each plus postage.
[Edited on 2/10/16 by Talon Motorsport]
FuryRebuild
posted on 3/10/16 at 09:25 AM Reply With Quote
Just a positive observation - 12.1mm is perfect for reaming out to 1/2". You'd then have just the right hole. Reamers are cheap - just be sure to buy cutting oil as well.
www.furyrebuild.co.uk
nilocp
posted on 3/10/16 at 05:14 PM Reply With Quote
Thanks Talon 32mm would be the size I need.
Thanks Furyrebuild, I have reamers, quite alot actually, and cutting oil
Colin
