andrenel
posted on 4/12/05 at 04:25 PM |
steering wrong direction
Hi
I am using granada front hubs, the steering arm on granda used to face backwards, and my build now faces forward. this will cause the wheels to turn
left when I turn steering wheek right.
How do we change direction of the steering rack ?
flak monkey
posted on 4/12/05 at 04:35 PM |
You cant.... unless you have access to gear making equipment. Or want to make up a mini gearbox (only need 2 gears, though I am not sure if anyone has
tried it!)
You need to find a rack from a front steer car. Ie a Mk2 escort or a sierra....
Why are you using Grandad hubs anyway? Why not use the standard Sierra?
Sera
http://www.motosera.com
omega 24 v6
posted on 4/12/05 at 04:38 PM |
ust a thought but if you could get a lhd rack and use it upside down would this cure the problem.?????????
Just a thought I'm not sure though Anyone confirm or tell me to not be so stupid.
flak monkey
posted on 4/12/05 at 04:40 PM |
Just another thought....by turning the uprights upside down you will seriously screw up their geometry!!
Sera
clbarclay
If you've turned your hubs around, won't that affect the ackerman geometry, arms pointing in (relativerly) when the should be pointing out
IIRC.
posted on 4/12/05 at 04:42 PM |
What car did you take the steering rack from ????????????????????????????????????????
70s Grandad steering arms face forwards as do Cortina -- it was built on a Cortina floor pan.
80s & 90s Granada Scorpio steering arms also face forwards as do Sierra --- it was built on a Sierra floorpan.
[Edited on 4/12/05 by britishtrident]
omega 24 v6
posted on 4/12/05 at 04:50 PM |
I didn't mean to turn the hubs or the uprights I just meant to get a lhd rack and turn it . The pinion would change from top to bottom or
v/versa therby changing the direction of movement required. It would also bring the pinion over to the rhd side of the car. You would only have to
turn the balljoints of the track rod ends to suit the upright. Or am I talking total pish.
flak monkey
posted on 4/12/05 at 04:56 PM |
Yeah we meant what he has done to the uprights. Turning uprights upside down isnt a clever idea!!
Turning the rack over wont make any difference to anything really.
If they are indeed Grandad uprights, then the steering arm should have faced the front on the donor anyway! As BT says....
Sera
Cita
posted on 4/12/05 at 05:08 PM |
Try it on your car and drive around a little
It will be akward but you'll get used to it after a while
Cheers Cita
Danozeman
posted on 4/12/05 at 05:36 PM |
LOl i once rode a bike like that. fell straight off!!
Dan
omega 24 v6
posted on 4/12/05 at 06:04 PM |
So was I right with my principles cita.
Cita
posted on 4/12/05 at 07:32 PM |
Me think so yes!
Rorty
posted on 5/12/05 at 05:00 AM |
Put the uprights on their correct sides?
Cheers, Rorty.
