Chazzy
posted on 29/8/06 at 06:11 PM |
sierra rear bearing loose
had an MOT advisory (still passed!) that one of my rear sierra based wheel bearings was slightly loose, been on road for 4 yrs never had this before.
its secured with a 41mm nyloc! i did it up originally, presumably to the correct torque. can I:
1) Get away with just pinching it up a bit more or
2) do i need to undo and replace nyloc to orig torque hoping it works, or
3) does it mean the bearings are buggered and i need to strip down, drift out and replace.
Chas
Liam
posted on 29/8/06 at 06:51 PM |
So the MOT tester must have felt some wheel wobble... Are you sure it definately isn't a wishbone bush/rod end?
If it really is the bearing check the torque. Just set your wrench and try it - if it tightens then it weren't torqued properly.
Liam
Mark Allanson
posted on 29/8/06 at 07:03 PM |
If the bearing has been running with play due to the nut coming slack - then it's knackered so replace.
If the preload is correct, then its knackered so replace.
The bearings on the other side have done exactly the same mileage, so replace as a precaution.
The consequences of a catastrophic failure are not woth thinking about.
Bite the bullet
Chazzy
posted on 30/8/06 at 07:16 AM |
The play disappears with the brakes on, so its not suspension bits (shame).
I can still remember how hard it was to put the shells in straight using just a hammer and length of rod, worrying that i'd slip and gouge out a
chunk of the surface...
what diy methods have others used?
Chas
mcerd1
posted on 30/8/06 at 08:59 AM |
Bite the bullet
Seconded
Sierra bearings are no-adjustable, you just torque them - so if there's too much play you'll need new ones
my old fiesta had ajustable ones where you tighten the nut untill you get just the right amount of play on the bearing - these are the type you could
just tighten a bit and maybe repace them once you've had to do it a few times
mcerd1
posted on 30/8/06 at 09:10 AM |
Chas
I used my dad's 30t press - its so much easier
you could use a very big vice but most probibly arn't that strong
if you know a garage or someone in a garage that would let you use there press (or do it for you for a couple of £)
otherwise .... ![](/images//smilies/sad.gif)
NS Dev
posted on 30/8/06 at 12:08 PM |
check they are tight. not unknown to loosen, especially if there was a dink in the hub carrier that prevented the bearing race from fully seating when
you first tightnened up the big nut.
Try tightening it up first, simple "torque" approach, as bloody tight as you can get it.
