Author: Subject: Zetec cams
oliwb
posted on 25/11/06 at 05:03 PM Reply With Quote
Zetec cams
Anyone know if these would fit a 2L as well???
http://cgi.ebay.co.uk/RS-1800-130-spec-zetec-cams-escort-fiesta-ford_W0QQitemZ120055884228QQihZ002QQcategoryZ21654QQrdZ1QQcmdZViewItem
Oli.
big_wasa
posted on 25/11/06 at 05:07 PM Reply With Quote
Yep but a waste of time and money as the 2l spec are meant to be a close match to them.
[Edited on 25/11/06 by big_wasa]
cct7kitcars
posted on 25/11/06 at 05:12 PM Reply With Quote
would these fit a 1600 zetec
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, Chardonnay in one hand, Tequila in the other, body bearing battle scars and totally worn out, screaming- WOO HOO!! What a Ride!
oliwb
posted on 25/11/06 at 07:56 PM Reply With Quote
Do black top cams fit on a silvertop zetec?? My engines a 130K miler and I'm planning on a full re-build so some newer even standard cams would be good on it.....Cheers Oli.
PS.
I take it that the 130 hp spec cams are just standard cams???
JackNco
posted on 25/11/06 at 08:26 PM Reply With Quote
im not sure but at a guess no. apparently the pistons are spaced differently
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
Schrodinger
posted on 26/11/06 at 12:10 PM Reply With Quote
The black top uses mechanical followers the silver top uses hydraulic followers and so the profiles are different and so you shouldn't use the black top cam on a silvertop without replacing the followers with mechanical followers.
