Tools
Tools…
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. Also useful for spinning drill bits in reverse
until the tip glows red.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija Board Principle. It transforms human energy into a crooked, unpredictable motion, and the
more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your
hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16" or
1/2" socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly
under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle.
TWEEZERS: A tool for removing wood and metal splinters made from a magical material that turns invisible when you need it, and re-appears when you
don't.
PHONE: Tool for calling your neighbours to see if he has another hydraulic floor jack. Also useful for calling the parts store and complaining that
the moron at the counter gave you what you asked for, and it's not the right one.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog poop off your boot.
How true is that?
