Sierra Wishbones & Chassis bracket positions
ludsonline - 30/3/16 at 05:53 PM
HI,
I've done a few searches on here & can't really find the answer I'm looking for. Does anyone have the drawings for Sierra Wishbones & Chassis bracket positions when using Sierra uprights?
This is what I've got at the moment, I want to check the wishbone dimensions
[Edited on 30/3/16 by ludsonline]
snapper - 30/3/16 at 06:43 PM
What kit are you building?
I would look at Haynes Roadster book as a starter
ludsonline - 30/3/16 at 06:49 PM
It's not strictly a Locost but it's got a 5 link Ford rear end & wishbone front
I'll search out the Haynes book
snapper - 31/3/16 at 07:08 AM
Haynes geo still applies or get the data on Sierra hubs and replicate camber and caster
If your brackets are wide enough you can pack top and bottom wishbones for caster, you already have camber adjustment on the top ball joint
[Edited on 31/3/16 by snapper]
ludsonline - 31/3/16 at 07:42 AM
I think I've found all the info I need.
Will need to check my chassis to see if it is anywhere near those dimensions & can be altered.
I'm going to be running 16" wheels on the project, so will need to alter it to suit those anyway.
